Program flow control: this is so lame
First of all I am going to apologize for this post but I am having issues trying to do program flow control using "If ... Then" statements and could not find anything in the archives. But I am tired so the answer is probably pretty obvious to the group here and another set of eyes always helps.
Here goes:
In trying to do program flow control, this is a chunk of what I have been doing:
Relay1:
If x=1 then Relay2
goto Relay3
Relay2:
Do task A
If y=6 then Relay 4
Relay3:
Do task B
Relay4:
Do task C
Goto Relay1
This works but the big question is: Can this be done more elegantly so I use less space in the BS-2? I have tried using IF THEN ELSE without any luck. Maybe something with a Branch command?
Any thoughts would be appreciated and thanks in advance for any pointers.
Gerry, the tired
Here goes:
Relay1:
If x=1 then Relay2
goto Relay3
Relay2:
Do task A
If y=6 then Relay 4
Relay3:
Do task B
Relay4:
Do task C
Goto Relay1
Gerry, the tired
