Apin with the counter modules
I'm playing around with the counter module and there seems to be a discrepancy between the data sheet is telling me and what I am experiencing. Pretty much I can only set Apin to be zero or a multiple of four. If I try to set it to some other pin, that pin puts out no signal. What am I missing? I have tried doing this by specifying the apin in a long that I copy to ctra and also by using movs to get the pin into ctra but neither works. I have tried this on the Professional development board and also the Propeller demo board so it shouldn't be something with my processor.
Here is the code that I am using:
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 var long temp pub start cognew(@counterStart, 0) repeat temp := 0 dat org counterStart mov dira,IOpins mov ctra,ctraData movs ctra,#8 mov frqa,frqaData jPoint nop jmp #jPoint IOpins long $11111111 ' make all pins be outputs ' It seems like Apin can only be zero or a multiple of four. ' Set up the peripheral into NCO/PWM single-ended mode ctraData long %00010000000000000000000000000000 frqaData long $40000000 fit 496
which should be the equivalent to the spin command:
With Spin I can set the pin to whatever I want but I would really rather not waste a whole cog on this. I would rather set up the counter at the beginning of another assembly language program and forget about it.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
And you can use constants from a CON section in PASM for the pin number.
Then your code will look like this:
But your versions will also work if you set the right pins as output(s).
Andy
-Jack
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
The ringing was shooting a good volt above and below my power rails.
Here is how it looked before the series resistor:
And here it is afterwards;
It still isn't perfect but looks better to me. Probably both are really fine for my application but I am driving the clock to an A/D so I was worried about the over and under shoot adding noise to my data.
I should say that I am overclocking this propeller to 100MHz rather than 80MHz. I'm not sure if that really matters since I am only having the counter run at 25MHz so the output driver isn't being pushed faster than it is spec'd for. Also, looking at my own picture, I see that at least as I was measuring it there, it was only ringing about .75V above and about .6V below the rails but still....
-Jack
·http://forums.parallax.com/showthread.php?p=885691
Jim
