source code version control recommendation?
Looking for something to help me keep track of changes to my programs. It's just me, not a team thing, if that helps.
Must run on Windows, hoping for free and easy to use.
- Stephen
The other great thing about subversion is it manages the CR/LF issues across the various platforms.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
They have command line support, a full windows gui client, and also support for other platforms (mac, linux, and several unix flavors). I can't imagine using anything else really.
Check out the Propeller Wiki·and contribute if you can.
A CON level 'variable' that can inserted into compiles.
It auto increments when the top level object is saved and is passed up or down between referenced objects and can be included in the file nomenclature.
Signature space for rent!
Send $1 to CannibalRobotics.com.
