Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here), 12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Yes ,,,I understand about the "Alias",,but you will have to post a warning or something on the panel or do something in software or most folks (students) will not understand...Most digital scopes( Tektronix or Hp) that I have worked with do not have problem with this...Irv
Hi Irv,
Scopes that quickly sample into a big memory buffer can "average" the data to prevent these artifacts. Unfortunately there is no way to do this with the Propeller. This is documented see section 3 of the Getting Started Guide:
"Tips:
- Select the right timescale
Digital oscilloscopes sample the input signal at configurable rates. (The PropScope samples up to 25 Million times/second) Sampling a signal too slowly will yield artifacts- so always look at a new signal with a faster timescale first."
Hanno
If you sample a signal too slowly, you'll get artifacts. There was a good discussion here: http://forums.parallax.com/showthread.php?p=883088
Hanno
"Tips:
Hanno
