Novice: need help with Xbee!!!! — Parallax Forums
Casey GrossCasey Gross Posts: 14
edited 2010-02-22 04:24 in Accessories
Im trying to send the value of a pot with one xbee to anouther but i get these weird numbers in the mix how can i make them go away?
EX RX:
48
13
59
0
48
13
10
48
13
10
48
13
10
48
59
0
13
10
48
13
10
48
13
10
48
13
59
0
48
13
10
48
13
10
48
13
10
48
    edited 2010-02-22 03:00
    Can't tell you without more information. At the very least, you have to post your source programs as attachments to a message. Use the Post Reply button and the Attachment Manager that shows up when you click on the button. In your message provide a description of how you have things hooked up if that's not documented in your source code.
    Casey,
    Your stream of data looks like ascii codes:
    48
    13
    10
    That is "0" followed by the ascii codes for carriage return and line feed. Ditto what Mike said.
    Tracy Allen
    www.emesystems.com
