X-Band Motion Detector-narrow field
Hello, could an aperture like barn doors (or some type of waveguide) be used to narrow the field or spot that is detected for the X-Band Motion Detector?
I would like to use this to detect if an object passes through a narrow area such as a car entering a driveway using the X-Band Motion Detector mounted high above.
Or, to detect birds passing through an area.
Thank you, Jeff
Thank you, Jeff
I'd be interested in your result. I wonder if angled outward might be better - not sure if the waves might bounce back and forth if they are parallel.
Trial and error might be the best approach...
Still in the brainstorming process.
A horn antenna might help with directionality.
Part of my wonders about putting some parasitic elements in front of it to draw out the beam.
You could use a parabolic dish and then built up an edge around it...then stick something on that edge to absorb/refract the RF (called a clutter shield)..this would limit what would spill over the side of the dish and reduce side-lobes.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
To limit the field of view, put the unit into a metal pipe. This creates swr and reflection/return loss issues, but it will limit the field of view.
A more technically correct solution is to use a coffee can or similar metal tube/pipe with end cap, but to line the back and sidewalls with microwave absorbing material. Using the absorbing material prevents/minimizes swr and return loss issues which will upset the proper operation of the microwave mixer inside the rf module.
The rf module is very quick and dirty with respect to design and functionality. So, don't get to carried away with improving it....some mods might make it perform even worse than it does already::>
