Flash_Stack_Test.spin example doesn't work with serial terminal
I just got the new propeller book and was trying to do the Flash_Stack_Test.spin example, but I can't get the serial terminal to work. I have copied the the code from the web page into a file called Flash_Stack_Test.spin, saved the file in the Propeller library with Stack Length.spin, have parallax serial terminal open, connected pin 16 to one of the led's on the propeller professional development board, loaded Flash_Stack_Test.spin onto my propeller professional development board, and I enabled the parallax serial terminal while Flash_Stack_Test.spin was loading. The led blinks on my professional development board, but instead of Stack Usage: 9 in parallax serial terminal, a y with two dots above it gets printed. Does anyone know what is going on?
