pot to display to relay — Parallax Forums
spudduditspuddudit Posts: 10
edited 2010-02-19 06:59 in BASIC Stamp
i want to use the basic stamp to do time lapse photography, idea is to use a potentiometer to adjust time delay and display it on two multiplexed 7 segment displays. i can get it to show the same number on both displays but cant get it to show say: 10 or 12. i had a working prototype, but it used 3 switches and a serious IF-then program to set and display preset delays. any one got ideas, i have been working through the stamp works book but it doesn't combine a display %10101010 code with IF-THEN codes
    edited 2010-02-19 00:52
    As with all questions like this, please attach the source code you're working with to your message along with a schematic of your setup. A scanned in drawing is adequate for the schematic.
  • spudduditspuddudit Posts: 10
    edited 2010-02-19 01:46
    dont realy have code yet like i said i was working with stamp works literature, here is what i started with though; it shows nothing about the LEDS the need to flash.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    index VAR Nib
    time VAR Word
    OUTH = %00000000
    DIRH = %11111111
    DO
    HIGH 0
    HIGH 5
    PAUSE 100
    RCTIME 5, 1, time
    LOOKDOWN time, <= [noparse][[/noparse]50, 100, 150, 200, 250, 300, 350, 400, 450, 500, 550, 600,
    650, 700, 750, 800 ], index
    LOOKUP index, [noparse][[/noparse] %01110111, %00101001, %00100011, %01000111, %10000011,
    %10000001, %00110111, %00000001, %00000111 ], OUTH
    loop
    my LED displays are backwards to i think because i had to do some experimenting to get the binary correct for digits 1 - 9
    %01110111 = 1
    %00101001 = 2
    %00100011 = 3
    %01000111 = 4
    %10000011 = 5
    %10000001 = 6
    %00110111 = 7
    %00000001 = 8
    %00000111 = 9
    also the LEDs are actually going to power two low voltage relay drivers, that tie into the stamp's VSS and VDD but if i can get the relays to flash correctly; ex
    high 2
    pause 400 ' focus relay
    high 3
    pause 250 ' close shutter
    low 2
    low 3
    hope thats more info......
    thanks
    Spuddudit
    896 x 640 - 52K
    edited 2010-02-19 02:08
    If you have the number in some variable, you can separate the number 10 or 12 or 99 into digits by:
    Take your variable and divide it by 10, the remainder will go in another variable. You'll then send the quotient to the tens display and the remainder to the ones display. It will go something like this:
    counter = pot value (Word sized variable)
    tens VAR Word
    ones VAR Word
    tens = counter / 10 ' divide the pot value by ten, put the result in the tens variabe
    ones = counter // 10 ' divide the pot value by ten, put the remainder in the ones variable
    out xxxx, tens ' send the tens to the tens display
    out xxxx, ones ' send the ones to the ones display
    SO, if your pot reads 10
    tens = 10 / 10 or 1
    ones = 10 // 10 or 0
    if your pot is 99
    tens = 99 / 10 or 9
    ones = 99 // 10 or 9
    I hope it helps!
    "puff"...... Smile, there went another one.
    edited 2010-02-19 02:24
    how would that work with my current code? or how do i know what the pot reads? ( what i tell it to display?) sorry there for a bit i kinda though i was pretty good with the project in the " whats a micro controller book" then i started on " stamp works" gets pretty in depth in a hurry....
    edited 2010-02-19 02:25
    also how do i tell it when 60 is displayed to pause 6000 between LED flashes?
    edited 2010-02-19 04:43
    Hmmm, well the pot value would be a function of your "time" variable. You'll probably have to scale it in some way to get what you want by multiplication or division...... but in my code, counter = time.
    "also how do i tell it when 60 is displayed to pause 6000 between LED flashes?"
    that would be done by scaling the result in "time". I'd start by setting the pot at some point and use a stop watch once it's all running...... Then adjust your scale (multiply or divide) to make the pot equal the time scale you want. Either that or adjust your R and C values.....
    I can't help you with sending the "tens" and "ones" values to the display. You are using commands I'm not familiar with. But since you've got numbers currently displaying, it shouldn't be too hard.
    edited 2010-02-19 04:59
    well i dont really have much displaying at all, i can get 0-9 to display on one or both displays by turning the commons high/low. butif you have code ideas that i can play with i would really appreciate it i kinda just grabbed something offline to start with but i think its going to have to be something more like: ( with sub-rutines to do the display side)
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    [noparse][[/noparse] Program Description ]
    ' This program takes an external 1 Hz signal from the pulse generator and
    ' synthesizes a simple clock/timer. This code will run, unmodified, on and
    ' BS2-family module.
    [noparse][[/noparse] I/O Definitions ]
    Segs VAR OUTL ' Segments on P0 - P7
    Digs VAR OUTC ' Digit control pins
    Tic PIN 15 ' 1 Hz input
    [noparse][[/noparse] Constants ]
    Blank CON %00000000 ' all segments off
    DecPnt CON %10000000 ' decimal point on
    IsHigh CON 1
    IsLow CON 0
    [noparse][[/noparse] Variables ]
    nTic VAR Bit ' new tic input
    oTic VAR Bit ' old tic value
    xTic VAR Bit ' change (1 when 0 -> 1)
    secs VAR Word ' seconds
    time VAR Word ' formatted time
    theDig VAR Nib ' current display digit
    [noparse][[/noparse] EEPROM Data ]
    ' .GFEDCBA
    Digit0 DATA %00111111 ' digit patterns
    Digit1 DATA %00000110
    Digit2 DATA %01011011
    Digit3 DATA %01001111
    Digit4 DATA %01100110
    Digit5 DATA %01101101
    Digit6 DATA %01111101
    Digit7 DATA %00000111
    Using 7-Segment LED Displays · Page 69
    Digit8 DATA %01111111
    Digit9 DATA %01100111
    DigSel DATA %1110 ' digit 0 active
    DATA %1101 ' digit 1 active
    DATA %1011 ' digit 2 active
    DATA %0111 ' digit 3 active
    [noparse][[/noparse] Initialization ]
    Reset:
    Digs = %1111 ' all off
    DIRS = $0FFF ' make segs & digs outputs
    [noparse][[/noparse] Program Code ]
    Main:
    DO WHILE (Tic = IsHigh) ' wait during high cycle
    GOSUB Show_Clock
    LOOP
    DO WHILE (Tic = IsLow) ' wait during low cycle
    GOSUB Show_Clock
    LOOP
    secs = secs + 1 // 3600 ' update current time
    GOTO Main
    [noparse][[/noparse] Subroutines ]
    Show_Clock:
    time = (secs / 60) * 100 ' get mins, move to 100s
    time = time + (secs // 60) ' add seconds in 1s/10s
    Segs = Blank ' clear display
    READ (DigSel + theDig), Digs ' select digit
    READ (Digit0 + (time DIG theDig)), Segs ' move digit pattern to segs
    IF (theDig = 2) THEN
    Segs = Segs | DecPnt ' add decimal point
    ENDIF
    like i said i really appreciate any input and if i should throw my begining code away "eah owell, worse things could happen.. (PUFF)"....
    edited 2010-02-19 05:42
    Where do you ever set "theDig"? Like all variables, it's initialized to zero. How about using a FOR / NEXT loop in Show_Clock?
    FOR theDig = 0 to 2
    Segs = Blank
    ENDIF
    NEXT
    edited 2010-02-19 06:51
    i am not at all familiar with the "theDig" command can you send a link so i can read up some? i guess maybe more basic terms for me, wow no i just straight up feel tarded.... lol thanks
    "theDig" is not a command. If you look at your program, you'll see that you've declared it as a variable.
