Boe Bot as mini sumo — Parallax Forums
edude632edude632 Posts: 3
edited 2010-02-20 14:49 in Robotics
Can a Boe Bot be configured to be used as a mini sumo bot wit the right partssensors programs?
    edited 2010-02-18 23:29
    Yes.
    - Stephen
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-02-19 02:24
    But it will not be legal. Mini sumos are max 10 cm x 10 cm. Your local club may not care. And you can use the BOE Bot to gain experience.
    John Abshier
  • edude632edude632 Posts: 3
    edited 2010-02-19 03:18
    thanks guys so what do i need to convert it? Btw would you recomend this robot· is it build up able? customizabel easy to program thanks!
    edited 2010-02-20 00:44
    You'll need at least one, preferable two line sensors to detect the edge of the ring. Parallax sells the QTI sensor that should work for this purpose and it is cheap. I think boe bot has some IR sensors which you can use for opponent detection. So some sort of plow mounted on the front would be good for helping lift and push opponents.
    The software to control this should be simple. Generally you hit the start button and the robot must wait 5 seconds. It then seeks out its opponent using the IR and rams them. If the edge of the ring is detected it should back off.
  • WhitWhit Posts: 4,191
    edited 2010-02-20 02:03
    edude632,
    Download the SumoBot manual here in pdf for free. It should give you some good ideas.
    http://www.parallax.com/Portals/0/Downloads/docs/prod/robo/sumobotman.pdf
    Also look here for parts - http://www.parallax.com/Store/Robots/RollingRobots/tabid/128/CategoryID/3/List/0/SortField/0/Level/a/ProductID/316/Default.aspx
    This is for the SumoBot Complete - but if you click a part on the parts list - the individual part comes up.
    Be careful on buying too many parts - before you know it - you could have bought the whole kit!
    Have fun and good luck. Post some pics when you get it going.
    Whit+
    edited 2010-02-20 05:22
    one more quick question im a nembie and i just want something i can program to do a lot of things should i get the boe bot or the mini sumo kit?
    If you are looking to learn - I would get the BoeBot. It has lots of accessories that will keep you busy. The BoeBot and its manual will teach you all sorts of things. Unless you need the serial cable, get the USB version - they are the same price. Just look around on the Parallax website. You can find grippers, legs, tank treads, remote control kit, and all sorts of sensors. So - it is very easy to expand as you learn more.
    Check out the Robotics with the BoeBot manual for free here http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Roboticsv2_2.pdf
    If you keep your eye open on the Daliy Deal, you may even find it on sale or wait for a free shipping weekend and save the shipping costs.
    Whit+
