64K vs. 32K EEPROM test
I want to test (run-time) if the propeller is being supplied by a 32K EEPROM or larger (64K or maybe more). Is there any way to query the EEPROM IC to get an answer? Or do I need to write to a location above $7FFF and see if I can then read the written value? Is it going to read only the bottom 15 bits of the supplied address (on a 32K), or something like that, and loop back to the beginning of the EEPROM or will it fail in some way I can detect?
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Some of my objects:
