PE Kit :(
I just got my kit yesterday. I took my time and read the setup stuff, then a good nights sleep to start the next day on getting her built. Well today I find that I am missing 1 of the 2 big 1000mF caps.. So I have called. and Parallax will send me one, but I really wanted to start today. My question is should I wait for the "official" cap, or go buy one from Fry's or RS? Not sure if there is a tolerance situation here or not? Cap is a cap is a cap..... Dang it!! I will probably wait. As long as I have the Prop, Plug, crystal, and eeprom, anything else (if missing) can be of the shelf, or not a good idea?
Robert
Robert
It is not problem to buy other CAP only You muse see it have correct Voltage tolerance (BIGER OK) but not to small.
Regards
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
[noparse][[/noparse]color=#008000>http://designedbymemicros.blogspot.com/
If You read entire Forum and see how many people burn theirs PLL that them not use CAP's on bredboard maybe YOU learn You USE them.
Regards
Sapieha
· Spin on!
00100000
Post Edited (blind_bot) : 2/19/2010 12:40:22 PM GMT
circuits to blink LEDs using two 1.5-volt AA batteries to give 3 volts
and just run it off the batteries. It's well within spec sheet tolerance
of 2.7 to 3.6 volts as listed on the datasheet. Otherwise match the
ratings and it's ok to shop around for the capacitors.
humanoido
