Short Range Motion Sensor---Advice/Guidance/Help
I was wondering if anyone could point me in the right direction. I am looking for a short range motion detector. Something that could sense a basketball going right in front of it, but not a player moving around a few feet away. Ideally, it would be able to hook up to a computer and simply log in whenever the basketball comes near it. I do not know what the exact product name is for what I am looking for, I don't know if it exists, and I do not know where to look.
Specifically, I would like 2. 1 for above the rim, so that it can detect evety time a shot is attempted, and another under the net so that it can record when a shot goes in.
Any thoughts are appreciated, thank you very much!
2) Have you looked through the sensors that Parallax sells?
3) A PING))) might work. It's not really a motion detector so much as an object detector, but an object detector is really what you want (to detect the presence briefly of a basketball). You might be able to mount one attached to one of the brackets holding the rim, then the other one might be attached to the backboard below the rim so it's protected by the rim from the balls themselves. The pair of PING)))s could be triggered sequentially every 50 to 100ms which should give you more than enough time resolution to catch the ball.
The problem of the net moving is certainly one for consideration- perhaps something, almost like a lever, could be put just under the net to record when the ball goes in. I will look into those options: the Piezo Film Vibra Tab Mass and Flexiforce sensor kit. They both seem like great solutions for monitoring the shots that go in. And great point with hockey- I will research it. Someone on a different forum suggested the RFID chip technology, which would actually go into the basketball. I think they use this sort of technology in the world cup for soccer, but I am not sure how it works with hockey.
Thanks agan!
Thanks again!
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Another question though for Sam, how are you going to differentiate between a 2 point shot and a 3 point shot or a free throw??
As far as recognizing where the shot is from- I have a friend writing up some hardware and software for this. If all goes as planned, I will be able to attatch a screen to it showing a basketball court from above. The screen will highlight the part of the court that the shooter is to shoot from, and then log the statistics of shot percentages etc with the sensors.
