C Golf challenge?
RossH
@All,
I have been reading the SPIN Golf Challenge thread with interest (and some people have the gall to say that C is unreadable!)
This got me thinking - perhaps someone (someone cleverer than me) should come up with a C Golf Challenge? After all, C beats SPIN hollow in its potential for both brevity and obfuscation. Below is an example (not mine - it won the C obfuscation awards in 1990).
And (before you ask!) - Yes it runs unmodified under Catalina (of course!).
Here is the command I used to compile it:
Before you either scroll down this post - or open the attachment - see if you can figure it out what it does:
What? Can't figure it out? Here's a BIG HINT - the above program will successfully execute the following (hello to all those PropBasic fans out there!):
Don't believe me? Try it! You will need a Prop with 256Kb of XMM RAM and an SD card (such as the DracBlade). Use the command above to compile it - instructions on how to run it are in the attached file.
Ross.
Catalina - a FREE C compiler for the Propeller - see Catalina
catalina -lcx -x5 -M256k -D DRACBLADE dds.c
#define O(b,f,u,s,c,a)b(){int o=f();switch(*p++){X u:_ o s b();X c:_ o a b();default[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]--;_ o;}}
#define t(e,d,_,C)X e:f=fopen(B+d,_);C;fclose(f)
#define U(y,z)while(p=Q(s,y))*p++=z,*p=' '
#define N for(i=0;i<11*R;i++)m[noparse][[/noparse] i ]&&
#define I "%d %s\n",i,m[noparse][[/noparse] i ]
#define X ;break;case
#define _ return
#define R 999
typedef char*A;int*C,E[noparse][[/noparse] R ],L[noparse][[/noparse] R ],M[noparse][[/noparse] R ],P[noparse][[/noparse] R ],l,i,j;char B[noparse][[/noparse] R ],F[noparse][[/noparse] 2 ];A m[noparse][[/noparse] 12*R ],malloc
(),p,q,x,y,z,s,d,f,fopen();A Q(s,o)A s,o;{for(x=s;*x;x++){for(y=x,z=o;*z&&*y==
*z;y++)z++;if(z>o&&!*z)_ x;}_ 0;}main(){m[noparse][[/noparse] 11*R ]="E";while(puts("Ok"),gets(B)
)switch(*B){X'R':C=E;l=1;for(i=0;i<R;P[noparse][[/noparse] i++ ]=0);while(l){while(!(s=m[noparse][[/noparse] l ]))l++;if
(!Q(s,"\"")){U("<>",'#');U("<=",'$');U(">=",'!');}d=B;while(*F=*s){*s=='"'&&j
++;if(j&1||!Q(" \t",F))*d++=*s;s++;}*d--=j=0;if(B[noparse][[/noparse] 1 ]!='=')switch(*B){X'E':l=-1
X'R':B[noparse][[/noparse] 2 ]!='M'&&(l=*--C)X'I':B[noparse][[/noparse] 1 ]=='N'?gets(p=B),P[noparse][[/noparse] *d ]=S():(*(q=Q(B,"TH"))=0,p
=B+2,S()&&(p=q+4,l=S()-1))X'P':B[noparse][[/noparse] 5 ]=='"'?*d=0,puts(B+6):(p=B+5,printf("%d\n",S
()))X'G'[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]=B+4,B[noparse][[/noparse] 2 ]=='S'&&(*C++=l,p++),l=S()-1 X'F':*(q=Q(B,"TO"))=0;p=B+5;P[noparse][[/noparse] i
=B[noparse][[/noparse] 3 ] ]=S();p=q+2;M[noparse][[/noparse] i ]=S();L[noparse][[/noparse] i ]=l X'N':++P[noparse][[/noparse] *d ]<=M[noparse][[/noparse] *d ]&&(l=L[noparse][[/noparse] *d ]);}else p=B+2,P[noparse][[/noparse]
*B ]=S();l++;}X'L':N printf(I)X'N':N free(m[noparse][[/noparse] i ]),m[noparse][[/noparse] i ]=0 X'B':_ 0 t('S',5,"w",N
fprintf(f,I))t('O',4,"r",while(fgets(B,R,f))(*Q(B,"\n")=0,G()))X 0:default:G()
;}_ 0;}G(){l=atoi(B);m[noparse][[/noparse] l ]&&free(m[noparse][[/noparse] l ]);(p=Q(B," "))?strcpy(m[noparse][[/noparse] l ]=malloc(strlen(p
)),p+1):(m[noparse][[/noparse] l ]=0,0);}O(S,J,'=',==,'#',!=)O(J,K,'<',<,'>',>)O(K,V,'$',<=,'!',>=)
O(V,W,'+',+,'-',-)O(W,Y,'*',*,'/',/)Y(){int o;_*p=='-'?p++,-Y():*p>='0'&&*p<=
'9'?strtol(p,&p,0):*p=='('?p++,o=S(),p++,o:P[noparse][[/noparse] *p++ ];}
10 REM Lunar Lander 20 REM By Diomidis Spinellis 30 PRINT "You aboard the Lunar Lander about to leave the spacecraft." 60 GOSUB 4000 70 GOSUB 1000 80 GOSUB 2000 90 GOSUB 3000 100 H = H - V 110 V = ((V + G) * 10 - U * 2) / 10 120 F = F - U 130 IF H > 0 THEN 80 135 H = 0 140 GOSUB 2000 150 IF V > 5 THEN 200 160 PRINT "Congratulations! This was a very good landing." 170 GOSUB 5000 180 GOTO 10 200 PRINT "You have crashed." 210 GOTO 170 1000 REM Initialise 1010 V = 70 1020 F = 500 1030 H = 1000 1040 G = 2 1050 RETURN 2000 REM Print values 2010 PRINT " Meter readings" 2015 PRINT " --------------" 2020 PRINT "Fuel (gal):" 2030 PRINT F 2040 GOSUB 2100 + 100 * (H <> 0) 2050 PRINT V 2060 PRINT "Height (m):" 2070 PRINT H 2080 RETURN 2100 PRINT "Landing velocity (m/sec):" 2110 RETURN 2200 PRINT "Velocity (m/sec):" 2210 RETURN 3000 REM User input 3005 IF F = 0 THEN 3070 3010 PRINT "How much fuel will you use?" 3020 INPUT U 3025 IF U < 0 THEN 3090 3030 IF U <= F THEN 3060 3040 PRINT "Sorry, you have not got that much fuel!" 3050 GOTO 3010 3060 RETURN 3070 U = 0 3080 RETURN 3090 PRINT "No cheating please! Fuel must be >= 0." 3100 GOTO 3010 4000 REM Detachment 4005 PRINT "Ready for detachment" 4007 PRINT "-- COUNTDOWN --" 4010 FOR I = 1 TO 11 4020 PRINT 11 - I 4025 GOSUB 4500 4030 NEXT I 4035 PRINT "You have left the spacecraft." 4037 PRINT "Try to land with velocity less than 5 m/sec." 4040 RETURN 4500 REM Delay 4510 FOR J = 1 TO 500 4520 NEXT J 4530 RETURN 5000 PRINT "Do you want to play again? (0 = no, 1 = yes)" 5010 INPUT Y 5020 IF Y = 0 THEN 5040 5030 RETURN 5040 PRINT "Have a nice day."
Ross.
Strangely enough I cannot compile that with GCC v 4.3.2 under Debian. Or at least I have not found the right options to do so. Tried - ansi, -std=c89 etc with no luck. Some give more errors than others.
However GCC for the ZPU is version 3.4.2 and compiles it just fine.
Sadly Zog is not quite up to running any C on the prop just yet.
The "obfuscated C" pages do say that some compilers will be unable compile some of the competition entries - especially the older ones. I guess gcc 4.x.y is "stricter" than both Catalina, or gcc 3.x.y (it also compiles using 3.4.5 and 3.4.6).
Ross.
I have a hard time nowadays getting my C++ and Qt projects to crash [noparse]:)[/noparse]
