Eight Channel Light Controller ==== Reached My GOAL ---- Propeller
I finished my first project outside of the Boe-Bot ,Stampworks and Propellor Education Kit books. It drove me nuts at times,but was worth it.
Could some of you go over it and make a some kind of a report card· for me. I would like to see where I could do it better.
This Object is to control 400 feet of 4 colored lights, and a traffic light.
I know its not a very neat mix of methods, BUT it does do everything I wanted. After I got it up and running I went on and cleaned up the documentation·on all the methods. Then complied·it and it would not work right, I was going nuts trying to get it running··before I realized the battery was too weak (Boy that sure does make you go over it again and again).
I want to thank the FORUM for all the help and input.
BillS
· Louisville KY.
Added 5-29-10
Link to one of the lightshows
http://www.youtube.com/watch?v=lnyGI87az5k
This one is with fast rate for the lightshow
Each boat slip is to take care of bulbs infront of the slip,most have updated the bulbs to CFL's but a few have not.
Most of the boats were out for the night thats why there are only a few boats docked
http://www.youtube.com/watch?v=OVWjxYe106g
Life is fun with a Prop.
BillS
··· Louisville KY.
Post Edited (lockadoc) : 5/30/2010 4:31:37 AM GMT
BillS
· Louisville KY.
Added 5-29-10
BillS
··· Louisville KY.
Fantastic project well accomplished!
I like the schematics in the spin file
and the documentation, and overall
project layout.
humanoido
The only thing I would worry about is grounding pin 8 with the relay. When you go to read the LDR you are creating a dead short when you make pin 8 high.
Other than that, it looks good to me.
Nice Job.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
I tried all sorts of things to make the light displays work when it was dark, that was the only way that I came up with that worked.
BillS
··· Louisville KY.
Tia'Shar Manetheren
BillS
··· Louisville KY.
added 4 more light displays· to have one color of bulbs light up· for a few minutes to check they were in the right order and working
also changed the road sensor from pin 30 to pin 14
BillS
··· Louisville KY.
I Wonder if if is possible to expand this project to include more light circuit's and include touchscreen to control the system ???
The Propeller Chip Has Opened UP My Mind To All Kinds Of Possible Things !!!!!
Thanks.
Doug Smith
BillS
··· Louisville KY.
MS_001·· = 80_000_000 / 1_000
Might instead use something like this...
MS_001·· =· clkfreq /·1_000
...then no matter what speed the Propeller is set to, or perhaps replaced with a new faster Propeller 5 years from now, the timing should stay the same. Test by slowing down the Propeller speed and see if the timing remains the same. This is mentioned in the waitcnt documentation or in the Propeller Education Kit Labs manual around page 62.
And if you ever incorporate a left turn signal, there is NEVER enough time allocated for left turns! Or the left turn signal will turn red *just* before I get there! So add a few extra seconds for me to get through the light please.
you are right about the " MS_001·· = 80_000_000 / 1_000···· " line, I did not notice that I did it that way.Must of been one of my late night computer·Loose track of time nights, and everytime I looked at it sence I·just sailed right past it.
Thank you for pointing it out .
I will update the code for it.
BillS
··· Louisville KY.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
on the "lightshows"· I was amazed how high the RATE could get up to with CLF bulbs that we have on the light chain.
Con
·· Rate =16·························· 'Variable used to change display speed
·· MS_001·· = 80_000_000 / 1_000································ ' ticks per millisecond····
PUB LightShow4
··· dira[noparse][[/noparse]0..7]~~
······· dira[noparse][[/noparse]18] := outa[noparse][[/noparse]18] := 1················ ' Set pin 18 to output-high
······· pause(100)··
··· repeat 10
······· outa[noparse][[/noparse]0..7] := %10001000
······· waitcnt(clkfreq/rate + cnt)
······· outa[noparse][[/noparse]0..7] := %11001100
······· outa[noparse][[/noparse]0..7] := %11101110
······· outa[noparse][[/noparse]0..7] := %11111111
BillS
··· Louisville KY.
BillS
··· Louisville KY.
