NEW: El Jugador Gaming Module for Propeller Platform
El Jugador adds Video, Audio, 2 NES controller jacks, and an SD Card Slot to the Propeller Platform. It also comes with a bootloader so you can run programs directly from the SD Card (no Prop Plug required). The SD card slot is also pre-soldered.
Project Page
Here are the design files (All files are available under the MIT License)
Layout (.pdf) (.dip)
Schematic (.pdf) (.dch)
Bootloader (sourcecode) (.binary)
Pinouts:
SD
p0 - Do
p1 - Clk
p2 - Di
p3 - Cs
Audio
P11 - Audio Out
Video
P12-P14
NES
P23 - Clk
P24 - Latch
P25 - Pad1
P26 - Pad2
The Video and audio are the same as the demoboard. the NES controllers are the same on the hydra with a 2 in front (P3 becomes 23, P4 becomes 24, etc). Pinouts are also on the board.
Here's a demo video of the bootloader.
Baggers contributed the SD bootloader (with a little tweaking from OBC). The bootloader is based on femtobasic's fsrw objects from Tomas Rokicki & Mike Green. THANKS GUYS!
As always, let me know if you have any questions / feedback / etc.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Project Page
Pinouts:
SD
p0 - Do
p1 - Clk
p2 - Di
p3 - Cs
Audio
P11 - Audio Out
Video
P12-P14
NES
P23 - Clk
P24 - Latch
P25 - Pad1
P26 - Pad2
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Here's a photo of the underside
The SD card slot comes pre-soldered.
Using an SD card to carry over binaries isn't the most convenient way to program, but it removes a barrier to entry. I started with a ybox2 partially because it didn't require a prop plug. Hopefully, if a beginner picks up El Jugador, they'll catch the bug and want to learn more about electronics.
The other thing I like about it is that it's modular - if you get bored with game programming, you just pop it off and drop on another module.
