Help with parallax serial servo controller
Hi, i'm working with the parallax serial servo controller and the BS2, i can move the servos in each channel sending the position. but i need move the servos with a butons, some like this, when i push the buton number 1 the servo turns to the left but when i release the buton the servo should stop in this position. and for the buton number 2 the same case but the servo turns to the right. is something like a proportional control but with the serial servo controller.
i would like to know if exist some comand for stop the servo when i release the buton and can maintain that position of the servo and when i press the buton again the servo continues to move.
gretings and many thanks
Do you have any code that you are working with currently? For example, do you have some that is or is not working the way you had anticipated? What hardware do you have? Any information as to what you have or what you have already done will help a great deal to others trying to offer suggestions.
Respectfully,
Joshua Donelson
www.parallax.com
