I found some "long 0-0" in the declairations area in PASM that I am not familar — Parallax Forums
OctahedronOctahedron Posts: 18
edited 2010-02-14 23:04 in Propeller 1
I was looking in N&V Spin Zone article·on SIRCS·and was making my way though the DAT code and ran across some long declarations that I have not seen before.· Here is the complete declaration section of the code:
DONE···················long··· true
NEG_DETECT·········long··· %01100 << 26··················· ' ctr neg detector
FREE_RUN·············long··· %11111 << 26··················· ' ctr logic always mode
START_BIT···········long··· 0-0···························· ' counts in 80% of 2.4ms
ONE_BIT·············· long··· 0-0···························· ' counts in 80% of 1.2ms
MS_044··············· long··· 0-0···························· ' counts in 44ms··
irmask················· long··· 0-0···························· ' pin mask for ir input
okpntr················· long··· 0-0···························· ' pointer to ready flag
codepntr·············· long··· 0-0···························· ' pointer to ir code
bitspntr··············· long··· 0-0···························· ' pointer to bit count of code
irwork·················· res···· 1······························ ' workspace for ir input
bits····················· res···· 1······························ ' # bits in input
tmp1··················· res···· 1
tmp2··················· res···· 1
··························fit···· 492
Now I have seen and used·all of them except for the "long 0-0".· Does someone have a quick explanation?
Thanks for your time.
  • heaterheater Posts: 3,370
    edited 2010-02-14 19:41
    blabla long 0-0
    Is a convention that has grown up among Propeller programmers to indicate to the reader that the variable is subject to being changed as part of a self-modifying code sequence. You will often see this where source or destinations addresses of an instruction are modified to create indexed addressing and such. e.g
    MOVS get, #3 'Set source address of instruction at "get" to 3
    get MOV A, #0-0 'When executed this instruction will have the source address modified.
  • AleAle Posts: 2,363
    edited 2010-02-14 19:44
    They are just placeholders. I thought they where instructions with fields with 0-0 (used to indicate places that will be overwritten with addresses/values during execution).
    In those cases AFAICT they do not mean nothing special.
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
  • OctahedronOctahedron Posts: 18
    edited 2010-02-14 21:30
    Thank you Ale and heater!
  • JonnyMacJonnyMac Posts: 9,846
    The code you list is something I wrote. Yes, the intention of 0-0 (that I picked up from another programmer here) is to indicate that this value will be modified by another section of code. In this specific case the ticks for a START_BIT, for example, are dependent on the system frequency. If you look in the initialization code in the object you'll see that these values are set using clkfreq and some divisor.
    Jon McPhalen
    Hollywood, CA
    Post Edited (JonnyMac) : 2/14/2010 11:09:12 PM GMT
