Propeller I/O Pin Configuration?
Is there a document that shows the structure of the I/O pin hardware topology? Often data sheets contain a pictorial diagram of the FET arrangement for an I/O pin, but so far I haven't seen that for the Propeller.
The reason I ask is I'm looking for what the pin looks like in an input configuration. I have a number of pins driving 2N7000 FETs. At boot-up, while the pins are still in an input configuration, the 2N7000's are going active. A pull-down is the correct solution, but I'd like to know what the largest value resistor I can safely use is.
--jc
--jc
