How would I change this circuit for the propeller?
P!-Ro
This is the OOPic circuit for the sonar module I'm trying to use, and I need to use it with the 3.3v Propeller.
PG
PG
I'm using the Polaroid version of this, with the only difference being 8 pins instead of 9: www.acroname.com/robotics/parts/R11-6500.html
I may also have a software problem, but I'll start with this for now to make sure I don't have circuit problem. I'll check that thread you talked about now, maybe the signal voltage is the only thing I need to fix?
PG
PG
PG
PG
