prop pager
anyone know were i can find a pager that can easily be hacked? i want the case and screen only. figure it would likely be cheaper then getting a tiny screen and custom made case. there does need to be enough room in it for a prop and rtc though so a tiny screen may be the way to go.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
cgi.ebay.com/Glenayre-Alpha-Numeric-Pager-Beeper-Skytel_W0QQitemZ350312880216QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5190465858
Not the fish.
sites.google.com/site/bitwinproject/
www.polycase.com/item/VM-24boot.html I have a couple if you want to see additional pictures than what's on their website.
I used to have my wife's old Motorola Bravo pager in my project boxes from the early 90s. I'll see if it's still there and take it apart if so.
Also, depending on what you are after, why not use a standard small plastic project case from Polycase, PacTec, etc, etc and then buy beltclip style velcro phone cases to put them in?
Have you looked into restaurant pagers or nursery pagers for other ideas? (they are way overpriced)
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
Post Edited (WBA Consulting) : 2/15/2010 6:53:17 AM GMT
