Help I need a Relay driver circuit
I need to drive a 5 volt relay from a Prop pin. I'll be using the relay to gound out a Photoreistor so it forces the R/C circuit its attached to to read 0.
I tried to do the same thing with code , but go nowhere with it.
BillS
·Louisville KY
BillS
·Louisville KY
Start on the main Parallax website and click on the Resources tab. You'll see a link to the Nuts and Volts Columns index.
"Give a lie twenty-four hours start, and it will take a hundred years to overtake it.
" (C.F. Dixon-Johnson, British author of the 1916 book, "The Armenians," appalled over the deceitful practices of his book's subject.)
www.tallarmeniantale.com/
I will see what I have in my Parts box and see which hint i'm going to go with.
BillS
· Louisville KY.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
Why not use a ULN2803 chip shown on the previous page in the N&V column? Less parts. And it includes the needed flyback diode. Just curious. I am using The ULN2803 driving 8 solenoids at 300ma each, driven directly from the Prop. Been on the bench 24/7 for 3 weeks cycling each solenoid once every second.
Jim
Jim
with this help I shoud have my project completed by Sunday night,I loom forward in Sharing with all here.
BillS
Louisville KY.
With this help I shoud have my project completed by Sunday night,I look forward in Sharing with all here.
BillS
Louisville KY.
using the prop pin to drive the relay works,I placed a diode between the prop pin and the relay coil,but what do you mean by the capacitor protection. None of the circuit diagrams I've seen use one.
Other than that My project is completed , just have to work on the documentation before uploading it.
BillS
Louisville KY
