newby question. — Parallax Forums
newby question.
jestaljestal Posts: 2
edited 2010-02-13 03:26 in BASIC Stamp
what hardware would it take to do the following?
dual temperature inputs, range: 70F to 220F. example of format (150.3 or 150.31), depends on the accuracy?
collect temperature readings every 15 seconds for a total of about 160 pairs of readings.
Offload the data to a pc.
Battery powered.
Smallest package size is required.
Is the Basic Stamp the right one for the job?
  • jestaljestal Posts: 2
    edited 2010-02-13 02:36
    I forgot to add: two Normally Open relay Contacts.
  • $WMc%$WMc% Posts: 1,884
    jestal
    Take a look @ the DS2760TC and the DS1620 just for starters.
    Use google
    Yes the Stamp will if set-up rite.
    The relays are the easiest part of Your project. Use a Transistor to drive the relay (3904 or a 3906) a (2N2222) will also work.
    The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
