Hitachi H48C Tri-Axis Accelerometer as seismometer?
Hi All,
I was looking at the specs of the Hitachi H48C Tri-Axis Accelerometer the other day and began wondering if anyone has attempted to use this unit to measure ground movements (earthquakes and tremors).
Wikipedia notes that earlier MEMS cantilever weight systems tended to be too noisy and were not sensitive enough for this application. But the H48C is a fairly recent development, and has a 12 bit A/D output. While this is nowhere near the 24 bit output of professional seismographs, yet it might be adequate for a strong-motion velocity sensor type of seismograph. And it is a full three axis unit in one package!
Anyway, thought I would put out the question to the forum. Anyone played with this?
Dave
Dave
Dave
·http://qcn.stanford.edu/
Jim
That is really interesting.
Dave
Post Edited (kf4ixm) : 2/12/2010 11:12:32 PM GMT
Is this the post you were refering to?
·http://forums.parallax.com/showthread.php?p=866552
Jim
Leon
Amateur radio callsign: G1HSM
That is a cool project! That is exactly the sort of feedback I was looking for. It looks like hover1 successfully found your post. I enjoyed reading that thread also. Even though I am considering using the prop for this idea, your BS2 code is very useful.
@hover1
Thanks for finding kf4ixm’s post for us.
@Leon
Thanks for the info. It is encouraging to know that the idea has merit.
Dave
Also, i had found doing some research and watching a series on either the science channel or nat geo channel about plate tetonics, i discovered that the north american plate actually moves southwest by approximatly 3" per year. this got me to thinking about upgrading the system to include a hm55b compass and gps sensor into this system to actually monitor the plate movement of the sensor array. one would of course have to take into account of magnetic declination, which for my position is +4° 23' EAST. (see here for you area)
I know a couple of years back when i checked it was around the 3 degree range, so it does change over time, i'm just not sure by how much. i for one would be interested in seeing what the gps postition and plate orientation is before and after a siesmic event. i know gps is gonna have some variations between readings, but my plan was to gather data over an hour, average that hourly·data, then log the hourly data and 24 hour data average. also using a high gain gps antenna, like helical or offset dipole arraingment, (like ones for we-fax i have built before)·to recieve the most satellites possible across the entire horizon instead of just looking up as in patch type antenna's.
Post Edited (kf4ixm) : 2/13/2010 5:07:05 PM GMT
I'll bet the prop will be able to take care of those Basic Stamp speed issues for you. Especially since you can load various processes into individual cogs where they can do their thing without disturbing other parts of your program. And not only that, there area all those cool prop objects just waiting to make your life easier by having already written code functions that you can just 'plug in' like a black box to do things for you.
If you are teaching yourself about the prop, I would highly recommend Andy Lindsay's Propeller Education Kit Fundamentals material. I have used it for several years with my beginning electronics students. It is very well written and progresses smoothly from concept to concept. And by the time you are finished with it you will have a good grasp of Spin programming fundamentals. As a bonus, the whole .PDF document is built right in to the Propeller Tool software. You can get to it under the Help menu in the Prop Tool.
Happy Spinning.
Dave
Thanks again!
i am· student of electrical engineerig. some one please tell me how to use or operate "hitachi H48C" Accelerometer.
thanking you in anticipation.
my email address is jj_4_u@hotmail.com
regards
muzzamil janjua
Check the Object Exchange for some samples:
·http://obex.parallax.com/objects/search/?q=H48C
Also the lower right corner of the product page has the Data Sheet and more downloads.
·http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/H48C/List/1/ProductID/97/Default.aspx?SortField=ProductName%2cProductName
Jim
