Universal Power Adapter with a Boe-Bot??
I have an old Radioshack (Archer) universal power adapter that I use a lot. Can I use it with the Boe-Bot board? I got it last year, so it is the newer version with the BS2 and the included USB adapter. What would the proper setting be? 6V? Should the tip be negative? I don't want to fry my board. Thanks!
Tell us about yourself & your 'bots.
I also had a general question I thought of while pondering power and batteries. I know you can connect batteries in parallel to maintain the same voltage while increasing capacity. So 4 AA batteries connected in parallel yields 1.5V, and should last as long as if you were using a single AA until discharged·and change it out 3 more times. Can I take a bunch of AA's that are mostly discharged, and hook them up in parallel to squeeze more power out of them. I often have to recycle batteries that still have juice in them, but not enough for whatever device they were powering. It would be nice to connect a bunch of the almost dead ones in parallel to power a breadboard project or 2. I always prefer less waste. And rechargeable batteries seem to always be a big no-no for projects like these. I don't really no why either...
