Interfacing with FRAM
Hello all,
I have a FRAM chip that I am trying to use for data storage with my BS2, but I am unsure of how to do so properly. The data sheet is attached, but I am unsure of what commands to send it. I believe I have everything wired correctly. I have pins 1-4 grounded, 5 and 6 are wired to I/O pins on the stamp (9 and 8, respectively), 7 is unconnected, and 8 is set to ~3V.
Right now, I am just trying to get a simple program to write data and read it back. If anyone has any advice or could point me in the right direction, it would be most appreciated.
Xan
Xan
pdf
125K
- Stephen
You would be much better off getting a 5V FRAM part if you can. The interfacing for a 3.3V part isn't difficult, but you could avoid it and concentrate on the software.
There are several Nuts and Volts Columns on interfacing EEPROMs and other I2C devices to a BS2p or BS2. The column for the BS2 includes sample code that you could use.
