Need a couple math routines — Parallax Forums
edited 2010-02-12 20:25 in Propeller 1
I've started using byte increments for calculating time in my game loops.
This works, but it would be handy to be able to perform functions based on timing.
Can someone help with a couple routines for determining if the byte is:
* an even number. (true/false)
* divisible by 5. (true/false)
OBC
New to the Propeller?
    edited 2010-02-11 15:05
    Even number? Just test bit 0.
    IF Value & 1 ' succeeds if odd
    IFNOT Value & 1 ' succeeds if even
    TEST Value,#1 wz ' zero true if even
    TEST Value,#1 wc ' carry true if odd
    Post Edited (Mike Green) : 2/11/2010 3:10:27 PM GMT
    edited 2010-02-11 15:09
    Divisible by 5 is harder. What's the range of values involved? Spin or Assembly?
    edited 2010-02-11 15:14
    @Mike
    Range is 0 - 254 in spin.
    OBC
  • jazzedjazzed Posts: 11,803
    edited 2010-02-11 15:17
    Use this for general purpose PASM: forums.parallax.com/forums/default.aspx?f=25&m=372927
    Note this line at bottom of code on OP: 'Reamainder is what left in arg1
    Spin is easy: ifnot number // 5 ' if true number is evenly divisible
    Here's an interesting link: mathforum.org/dr.math/faq/faq.divisibility.html
    Post Edited (jazzed) : 2/11/2010 5:15:32 PM GMT
    edited 2010-02-11 15:22
    Mike Green said...
    Duh.. (head smack) My brain seems to default to decimal numbering. So a test routine might look like..
    PRI CheckEven (timer) | even
        even := false
        IFNOT timer & 1
           even := true
        return timer
    OBC
    edited 2010-02-11 15:38
    You could simplify this even more with:
    PRI Even(thing)
       return (thing & 1) == 0
  • mparkmpark Posts: 1,305
    edited 2010-02-11 15:55
    jazzed said...
    Edit: if it's just to test divisible by 5:
    and number,#7
    cmp number,#5 wz
    if_nz test number,#0 wz
    That "last digit is 5 or 0" test only works in decimal! Your code fails if number is 10, e.g.
    edited 2010-02-11 15:56
    OBC: The counters are a good way for timing independent code. I recently started to play with them in pasm.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-02-11 17:12
    mpark said...
    jazzed said...
    Yuck snipped! [noparse]:)[/noparse]
    You're right. I was half asleep [noparse]:)[/noparse]
  • JonnyMacJonnyMac Posts: 9,208
    edited 2010-02-11 19:08
    The divide by 5 shouldn't be hard -- what about this?:
    pub divideby5(value)
      return ((value // 5) == 0)
    [noparse][[/noparse]Edit] -- I just saw that [noparse][[/noparse]another version of] this solution was previously posted.
    Jon McPhalen
    Hollywood, CA
    Post Edited (JonnyMac) : 2/11/2010 7:14:24 PM GMT
  • BocephusBocephus Posts: 58
    edited 2010-02-11 19:51
    If multiplication is faster than division in Spin?
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
    OBJ
      tv : "tv_text"
    PUB main | number, div_five
      number := 145
      div_five := $CCCD
      tv.start(13)
      tv.dec(number)
      tv.str(string(" divided by five = "))
      number := (number * div_five) >> 18
      tv.dec(number)
    edited 2010-02-11 20:02
    Multiplication in Spin is slightly faster than division. The overhead of fetching and decoding the byte codes would tend to mask any differences as well as pushes and pops needed. It would be easy enough to do the operation 10000 times and time it using the system clock, then repeating the same loop with the other operation and comparing the results.
  • VIRANDVIRAND Posts: 656
    edited 2010-02-11 21:21
    Magickalogickal Method:
    if (num8bits * $33) & $FF == 0 'if a number under 256 is divisible by 5 ...
    if (num16bits * $3333) & $FFFF == 0 'if a number under 65536 is divisible by 5 ...
    In assembly, this is done on LONGS with 16 shifts and 16 adds, and the result long = 0 if it divides 5 with zero remainder.
    (or just one MUL, if we had one)
    I am not sure whether this trick works with Spin variables defined as bytes or words, because it is an overflow trick.
    I also don't know if it has any advantage over // if the remainder is re-normalized by a division by the "hex 3" nybbles.
    This may fail on the number 5. If so, I would try fixing it by adding one to the variable being tested product.
    I haven't actually tried it, so it may not work at all.
    Bocephus method seems like a similar concept.
    Post Edited (VIRAND) : 2/11/2010 10:02:37 PM GMT
    edited 2010-02-11 21:37
    @Mike Green: You are right. I timed the two and I was surprised to see mine is slower.
    edited 2010-02-12 00:42
    'Thank ya, gang!
    OBC
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-02-12 02:03
    Little late to the party here but isn't anything multiplied by 2 ending in 0 divisible by 5? - if so then it's one bit shift to the left and test for dec 0?
    jim
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
  • tonyp12tonyp12 Posts: 1,951
    edited 2010-02-12 02:47
    As you are only dealing with 49 possible numbers (0-254), you could have a look-up table of these 49
    But I did a check for the last 4 bits and the pattern repeat after 16.
    so binary-and the number with %1111
    check if result is any of the 16 below.
    Is 0/5·valid?, if not check if start value <>0 as 80 have·same 4 bits as zero
    0101 5
    1010 10
    1111 15
    0100 20
    1001 25
    1110 30
    0011 35
    1000 40
    1101 45
    0010 50
    0111 55
    1100 60
    0001 65
    0110 70
    1011 75
    0000 80
    0101 85 < repeat
    1010 90
    1111 95
    0100 100
    1001 105
    1110 110
    0011 115
    1000 120
    Post Edited (tonyp12) : 2/12/2010 3:05:48 AM GMT
    edited 2010-02-12 03:11
    Is a see a repeat pattern in 8 with 3 bits
    and 4 only possible with 2 bits
    could be so simple as: if(number and%11)== 0 || 5 || 10 || 15
    00 0
    01 5
    10 10
    11 15
    00 20
    01 25
    10 30
    11 35
    00 40
    01 45
    10 50
    11 55
    00 60
    01 65
    10 70
    11 75
    edited 2010-02-12 03:14
    If you have the memory available just do a 255-byte lookup table.· It's probably the fastest way to do it in Spin.
    edited 2010-02-12 13:26
    You'd only need a 8 long lookup table then... 8x4=32bytesx 8bits=256 (including 0)
    There are 51 multiples of 5 between and including 0 and 255.
    There must be a solution involving the 2 lowest bits but I didn't think of that.
    Obviously the lookup table is going to be
    %100001000010000............................1000010000100001
    and is probably pointless to lookup when num//5==0 is available.
    Both bit and byte lookup tables waste memory and one wastes time except in PASM.
    edited 2010-02-12 14:50
    @tonyp12
    Problem with the two lowest bits is that they are not exclusive.
    05 => #0101 for last two bits also 1, 9, 13
    10 => #1010 for last two bits also 2, 6, 14
    15 => #1111 for last two bits also 3, 7, 11
    @Virand
    There are only 25 multiples of 10, 4 multiples of 50 and so on. What if you multiplied by 2 then chopped the number down the number to 3 bits. If it's a multiple of 5 then those are 000.
    edited 2010-02-12 19:16
    How do you propose to chop the number to 3 bits? Bitwise-anding %111 won't work. Suppose your original number is 4. Multiply it by 2 to get 8. The last three bits are %000 but 4 is not a multiple of 5.
    Simplest is probably a modified binary search. The multiple if statements could be replaced by a loop and a 6 byte array.
    if no > 130 no = no - 130
    if no = 0 then multiple of 5
    if no > 65 no = no - 65
    if no > 35 no = no - 35
    if no > 20 no = no - 20
    if no > 10 no = no - 10
    if no > 5 no = no - 5
