Do Loop in spin? — Parallax Forums
Do Loop in spin?
10gigbill10gigbill Posts: 79
edited 2010-02-11 16:19 in Propeller 1
I have a 9600 baud stream party-lined to several (5) props
Each prop has a one character “address” (unique char only used for addressing) that will have a 5 character command following for that address. I want to have a timer in the prop so that once it sees it’s address and starts to collect it’s 5 characters it will not hang if the party-line is interrupted. That is it should receive the characters in say .1 seconds. If not it should go back to looking for a new command string.
As soon as I see my address I start the timer and collect the next
5 characters while timer is not timed out. Do while….
BUT AAAARRRRGGGGGG…. There is no Do loop …..?
Sorry I’m new at this spin thing
Thank you for your support.
Bill
  • RossHRossH Posts: 5,738
    edited 2010-02-11 05:28
    Bill,
    In SPIN, the REPEAT loop does the job of all the usual DO/WHILE/UNTIL/FOR loop constructs. Check page 293 of the Propeller manual (v1.01).
    Catalina - a FREE C compiler for the Propeller - see Catalina
  • 10gigbill10gigbill Posts: 79
    edited 2010-02-11 05:47
    OK thanks... It's page 188 in prop manual (v1.1)
    I'll give this a try and maybe by tomorrow I'll get a little farther down the line on my project.
    Repeat (while...) hummmm......
    thanks
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-02-11 07:21
    What's the difference between a while loop and a do loop?
    The condition is checked at the beginning in one case and it's checked in the end in the other case.
    So, to turn a while loop into a do loop you'd simply choose a condition which is true in the first iteration.
    cond:=-1
    repeat while cond
      ' some code
      cond:= 'your condition comes here and must be 0 to exit the "do"-loop
    I have used that method to implement do loops as well.· It can get a little complicated if your loop contains "next" statements (same as C continue).· You would have to compute the new value of "cond" before each next statement.
    A slightly modified method is to OR a first-time flag with the normal "do" condition as follows:
    first := true
    repeat while first OR <condition statement>
    · first := false
    · next
    · next
    Another thing is that "repeat from" loops always execute at least once.· Also the "step" value is not the actual increment used, but it is a multiplier of the computed step value.· The following examples yields unexpected results unless you understand how the step value is used.
    for i from 0 to -10 step -2
    This will execute once with the final value of i being 2.· If I wanted to step through values of 0, -2, -4, -6, -8 and -10 I would need to use the following statement.
    for i from 0 to -10 step 2
    Also, a C statement of "for (i = 0; i <= num; i++)" does not translate directly to "repeat i from 0 to num".· If num is negative Spin will decrement "i" instead of incrementing it.· The C statement would need to be written in Spin as follows
    if (num => 0)
    · repeat i from 0 to num
