Is it ok to use 6 Volts Dc and 1.5 Amps on Basic Stamp 2 and servos
Hi guys
I am making Robot arm so my problem is my·Old adapter
got fried some how
which was 6 volts DC adapter and gives out 800 amps which i bought from THE Source·store and i am a student so i have question for smart people plz be smartt dont be dumb
if you dont know please dont reply because of your mistake my 4 servos and basic stamp 2 would fry. I am now thinking to get 6 volt dc adapter with 1.5 amps what you guys think is it ok to buy···· 6 v DC with 1.5 amps
adapter for basic stamp 2 and 4 servo motors i ha seen this adapter on HVW tech website i am connecting all together on bread board. Please reply quickly if you the answer. Ok
Servos are designed to work with power supplies from around 4.5V to around 7.2V with some excess brush wear at the higher voltages. 6V is just about right.
Stamps are designed to work with power supplies from 6V to 9V (if you're using the built-in regulator and Vin). You can also use a regulated 5V supply (directly to Vdd) as an alternative.
Servo motors generate a lot of electrical noise on their power leads (and the control lead as well). You can run a Stamp and some servos off the same supply, but you should add some filtering near the Stamp and near the servos. A 1000uF 16V capacitor within a few inches of the Stamp and another close to the servos would be great.
So sir you mean that i can use 6 v dc which gives 1.5 amps. If i am using basic stamp 2·and 4 servos. But before i was using 6 v dc adapter which gives 800 amps.
