How to test a 433MHz RF Transceiver
Hello all,
Does anyone know a method for testing the Parallax 433MHz Transceiver modules in order to find out if the onboard circuitry
hasn't been toasted?
I think there is a good chance through all of my initial trial and error with these modules that I have fubarred at least one of the two modules.
I'd like to find out for sure before paying to replace them.
It's not the size of the dog in the fight, but the size of the fight in the dog.
Leon
Amateur radio callsign: G1HSM
I currently have one transceiver on the BS2 homework board and the other on the Prop PDB.
I have the the below listed programs running on the respective boards with no real results. Would these actually tell me if they were working or
am I way off base?
mode14 is
On the BS2
Pin 14 is DATA
Pin 15 is TXRX
On the Pro
Pin 11 is TXRX
Pin 12 is Data
The BS2 program is similar in that it leaves the transceiver in receive mode with the data line driven low by the Stamp. If the transceiver's data line is high, that's again a short circuit and the transceiver and/or the Stamp I/O pin can be damaged.
The I/O pin connected to the transceiver data line must be changed to input mode before (or at the same time) the mode is set to receive. You can help prevent damage if you use a 220 Ohm resistor between the transceiver data line and the I/O pin.
tools to measure the voltages. I may have to go get them.
The below programs should work. In it's simplicity, all it's doing is setting one transceiver to a constant receive mode and the other to a constant
1 second high/low pulse.
Alright, in the middle of typing this post, I decided to swap the Transceivers and can now see an obvious problem. As I included
in the code sample, you can see that it pretty much works in one direction and doesn't in the other.
Should I continue testing and try something else or is this conclusive enough to make my decision to buy another?
(I have not bought the modules yet.)
Can the Transceiver Modules be used (for testing purposes) without STAMPS or Props,
as if they were for Morse Code? Maybe using an LED instead of a beeping piezo buzzer?
I suggest this because it may be very convenient, and also provide some immediate hands-on experience in using them,
for those who don't have a radio nor other more or less useful test equipment.
Also, a few years ago, the ESB caused severe technical problems with very powerful interference on 433MHz.
I don't know if they quit it, but if not, 433MHz may still be unusable in some parts of New York City.
The ESB put out a lot of power on it, and caused some serious technical problems a few years ago.
I should be typing in Spin now.
Coming soon. My open Propeller Project Pages and favorite links index.
These are Part 15 devices.· They have limits on how much transmitted power can be used (and how big an antenna).· They're secondary use, so there's nothing you can do about interference (except switch to some other frequency).
@eiplanner - I guess you need to replace the broken unit.· Be sure to call Parallax Tech Support.
I was so excited to finally have gotten to the stage where I was gonna plug in the transceivers and play with the wireless programming techniques.
I have been spending all this time since my last post working on WIRED serial communications between the BS2 and the Prop PDB. I have gained a
lot of knowledge in this process. As it was suggested to me by some good people on here, I too would recommend working on WIRED serial
communications before ever attempting WIRELESS. It really really really is the fastest way to learn with the least amount of obstacles. I can now
write the serial code myself to receive and transmit serial data without the use of any other objects. Which makes me very happy!
Thank you Mike Green, StefanL38, and Dr_Acula for all the help!
Unfortunately, after reading the specified bitrates and the modulation type, I have to agree that simple testing
of the transceiver modules by using them as manually controlled morse code radios (as is) is not supported,
because the AGC may cause decoding of the carrier at slower than specified rates as random bits.
Another idea that may be useful is to make square wave tones using a microcontroller outputting between
1200 to 9600 Hz into the transmitting module, and heard as a tone with a simple piezo (without a beep circuit)
at the receiving module's output. The tone, for practical test purposes, should produce a signal that is similar to
transmitting "U" characters at the beginning of a normal serial data transmission.
If this paragraph makes no sense, forget about it. Even my "simple" ideas are often bizarre.
I have test equipment, but I was pondering what others or myself can do without it.
eiplanner has apparently concluded that the serial-io should be working on the wire before trying on the air.
My comments on wired testing first were meant towards how a person should go about setting up a serial circuit for the first time.
It's just easier to get your code working first on a wired setup and then proceed to replacing the wires with a wireless device. This
subject was covered in another thread where Mike was coaching me so I just wanted to come back and say that I followed this
procedure and it worked well for me. It really had nothing to do with testing the transceivers, I just wanted to let Mike know my
progress. Sorry for going off the subject.
As far as my 433MHz Transceivers, I ran the posted programs above and figured out that I had one nonworking module. It would receive
but not transmit. I am quite sure I must have toasted it a few weeks ago before I ever learned how to properly use it. Being an electrician
and a newbie to electronics, I am still a little to aggressive with these sensitive components. I am learning though. In this case a $40 lesson.
I guess you're gonna pay for an education one way or another.
and so, the journey continues..........
I did not intend to choose words that imply any judgment or emotion. I was also responding to him
with ideas for simplifying testing the radio modules but even myself being unaware of your conversation
on another thread didn't change my meaning... I meant I AGREE that it's also good to test the other parts
of the project before the radios. I also thought that since most people don't have other equipment to measure or
transmit or receive on 433 MHz, there might be a simple way to test the radios using only the radios,
which may be helpful so that people won't have headaches looking at code if there is a radio problem,
or be frustrated by the radios if there's a buggy code problem. Just trying to help.
The simple method I used in constantly listening for a signal and a steady pulse happened to work for
my specific problem because my bad transceiver could still transmit. If it had been unable to transmit or
receive, I wouldn't have known which unit was bad. In that aspect, I was just lucky in finding the problem.
It probably does require an RF scanner or another type of radio receiving device to actually know for certain that the units are
producing a signal. But are they receiving the signal is the more difficult thing to test for. I suppose it would then come down
to tracing out the circuit through each component on the circuit board to find where the signal was lost. That's just speculation
on my part because it's beyond my current abilities.
