Switching 12V 1.6A valve (need ciruit checked)
Hi everyone,
Can someone please check this circuit and let me know if it will switch a water valve 12V DC (1.6 A)
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
Thank you
bmp
527K
R1 is too low, try 10K or greater ( unless you are switching at > 100Hz)
the mosfet wont do.
the VGS max for turn on is 4 volts, so a prop delivering 3.3volts wont turn on the mosfet.
Also an IRF540N is rated at 33Amps, so its totally overkill.
select a mosfet with a vgs max of 2 volts, and a continuous current of say 3 Amps.
the FDT439N is 90Cents, but its SOT-223.
http://www.fairchildsemi.com/pf/FD/FDT439N.html
this one FQP13N06L is TO220, and only 46Cents, but the worst case vgs turn on is 2.5volts @250uAmps, leaving only 3.3-2.5=0.8volts to really turn it on.
if its just a one of project, it will probably be OK, since its typical vgs turn on is about 1.8volts
http://www.fairchildsemi.com/pf/FQ/FQPF13N06L.html
So this should work?
mouser.com has the FQP13N06L for $0.825
Thank you
i assume you are driving the led with about 10mA, so better on the output.
I also assume you have only one or two valves, otherwise 10mA/pin from the prop could cause a problem if you drive the leds from prop pins.
Also, driving the led from the prop pin will reduce its Voh, so reduce the mosfet gate drive.
better put the led across the valve
Will put the led accross the valve.
Thank you Mike
I am assuming that it will cause a drop in voltage by the time it gets to the circuit.
In this case should I boost the prop output with a transistor before going to the cable?
Thank you
I will assume that you are only turning the valve on and off, not pwm'ing it.
If you must put the mosfet 1metre away from the prop, i suggest you put 2 off 1K resistors in series with the prop pin, and a 0.1uF capacitor down to 0 volts of the prop.
Also raise your R1 from 10K to 47K
this will act as a low pass filter to kill any noise being fed into the prop
prop
1K resistor
1K resistor
mosfet gate
0.1uF capacitor
GND (0volts)
mosfet source
put the 2 resistor, 1 capacitor pi filter close to the prop, and then run the cable to the mosfet, with R1 47K on the mosfet
I am still not quite sure how to wire up the led. I am assuming I put it in parallel to the diode with a 560ohm resistor in series.
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
the resistor value should be calculated so that between5 and 10mA is flowing through the led, so (12V-3V for the led)=9volts/10mA=1Kohms.
