tv test signal? — Parallax Forums
tv test signal?
irvirv Posts: 14
edited 2011-08-18 21:20 in Accessories
When will the tv test signal be available ???....Irv
  • HannoHanno Posts: 1,130
    edited 2010-02-08 22:31
    Hi Irv,
    That's a difficult one... The firmware currently uses all 8 of the Propeller's 8 cogs. Are people interested in a separate firmware that would disable the function generator but output a fixed tv signal?
    Hanno
    Co-author of the official Propeller Guide- available at Amazon
    Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
    12Blocks, the block-based programming environment (thread here)
    and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
  • irvirv Posts: 14
    edited 2010-02-09 17:58
    If the firmware was easy to load and then restore, then it would be no problem for me....Irv
    edited 2010-02-09 20:41
    What sort of signal would you like to see? Here are possibilities:
    - just an ntsc signal to look at- ie, a black screen
    - screen which continually updates measurements of ch1 and ch2 at a given setting- plug PropScope into TV for display
    - screen which has some control from the windows ui- ie, setting background color
    - color bars
    Hanno
  • irvirv Posts: 14
    edited 2010-02-09 21:13
    A screen that would be controlled from the scope window, ie ,one controllable color....Irv
  • BuildThingsBuildThings Posts: 31
    edited 2010-04-10 22:01
    Any headway on the video interface? That connector is just pleading to have something connected to it smile.gif
    edited 2010-04-10 23:00
    A simple video signal is coming in v1.05- and yes, making good progress on it, Parallax has started testing builds. A little while longer...
    Hanno
    edited 2010-04-12 21:10
    Great Hanno ! Can't wait to try it out.
  • FredBlaisFredBlais Posts: 381
    edited 2011-08-16 07:30
    Is the software done to use the propscope and plug it on a TV instead of the computer?
    If so, do you have some pictures?
    Fred
    Hi Fred,
    Yes you can connect a TV to the PropScope- it'll show you a realtime bar graph of the analog measurement as well as actual values.
    Hanno
