Stamp2 based simple acoustic modem?
Hi Everyone,
I have a requirement to transmit a very small amount of data (less than 25 bytes) over what has the potential to be a fairly long range, up to 10 miles or more. I've done some testing, and I can easily rig up a system where I can transmit some simple tones to convey the data I need. . .but I'm hoping to avoid buying a ton of expensive hardware to interface this with a PC on the receiving end. . .
So my question is this: Is there a way to quickly decode a series of tones into numerical values on the receiving side of this system? Right now I have the Stamp2 sending out a series of beeps that represent data. . .and I have to manually decide the data on the receiving end (yuk). Any ideas on a cleaner and more sophisticated solution?
FYI, currently the best solution I'm investigating is a DTMF solution as described here: http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv7.pdf but I can't seem to find any source for the CM8880 IC. . .any suggestions on alternatives would be great. . .I'd love to just use the N&V article as a guide here but it doesn't seem that I can!
-Jeff
Post Edited (everest) : 2/8/2010 9:02:09 PM GMT
-Jeff
-Jeff
Is this being transmitted over wire, or radio? If radio, be careful. In the US you can get into some serious hot water for violating FCC regs. Even with a ham license certain bands are limited to certain types of transmissions.
But if you are aware of any simple/cheap solutions that use other technology, definitely let me know!! I'm always open to new/better options.
-Jeff
-Jeff
http://kengracey.com/Home/RadioCommunication/tabid/73/Default.aspx
Very "off the shelf" approach. I love it!
-Jeff
