Parallax PIR Sensor problems
Hello everybody,
···· I am using a Parallax PIR sensor with the 3 pin header. (Power, ground, and Output) but I am having some serious problems with the output of the sensor always remaining high.
In my circuit the sensor is receiving a regulated 5 volts. the output is going into a PICAXE microcontroller to detect wether or not to do other things. The problem that I am having is very unusual and i'm not sure how to fix. When the system is first powered on the sensor goes through its initial warming up phase and then the output cycles between 3.6 volts and·0 repeatedly. this jumpy output is causing my microcontroller to detect multiple high low logic and freak out. I have tried putting a 10kohm pull down resistor on the output to clamp the output to 0 volts ·with no sucess and i have also tried placing a smaller input resistance going into my microcontroller to help prevent any voltage spikes into my system.
now here is the very strange part..... The system works just fine when i attach a voltmeter DIRECTLY to the output and ground·pins on the sensor to measure the output voltage.... whenever the voltmeter is removed (me thinking oh its working like its supposed to) the PIR sensor goes back into its rapid high low output state....
If i measure the input voltage @ my microcontroller and not directly on the PIR module is when i see the high low voltage transisitions which leaves me to belive there is some sort of problem with the PIR not the rest of my setup.
To make the situation even worse when breadboarded with the sensor just activating a simple LED the system works as advertised no problems.
I have also checked to make sure that when my system is activated that the output voltage to the PIR sensor does not drop below 4.8 volts. but even if it did it would not explain why a voltmeter (with its supposed infinite resistance) when connected between the ground and output pin fixes the problem...
If anybody can assist me with removing the ghosts from another dimension from activating my PIR sensor it would be greatly appreciated...
Quick Edit: the motion sensor is covered with black tape during testing, I have also covered it with towels and ect to make sure i wasn't accidentaly moving during testing.
Post Edited (Crono1124) : 2/8/2010 12:01:05 PM GMT
Dave
Dave Andreae
Parallax Tech Support·
·If the output is connected to an LED it works fine. If the output is not connected to anything it works fine. When its connected to the PIC is where the problems come in. Only solution i have that has worked so far is to apply a voltmeter and that seems to stabalize the output for whatever reason. Different PIC's yeilded the same result also so i can't understand what the problem may be.
I do know the PIC has an internal input resistance but to my understanding that shouldn't cause too much of a problem as far as the behaviour of an attached sensor.
The pinout on the PIC is configured to input only and it is not able to be configured as an output so there isn't a reason why the PIC would be able to drive the voltage high especially not to the exact output voltage of the PIR sensor. (again to the best of my knowledge.)
The PIC in use is a PICAXE 18X chip. the system i am using utilizes a 120-12VAC transformer, a full wave rectifier, a 5 volt linear regulator which then drives a 5.8Ghz Transmitter based on the output signal from the PIC via·a Transistor which is activated through the PIR sensor
so PIC input is PIR sensor. Pic Output 5volt TTL logic to Transistor Base. Transistor then provides power to transmitter via a Collector Emitter Induced Current.
For an occasion, there is no output when a ceramic cup covered the sensor.
For more accurate testing, I removed the plastic lens and covered a tiny window visible on metal part that is soldered on a board. It is still doing the same problem, which is giving me unstable output voltage.·
[font=ï¼*ï¼³ ææ]So it is more or less firmware problem in the sensors.[/font]
Both Parallax RIP sensors do have the same problem.
[font=
If the sensor works when just connected to an LED or voltmeter, but not when it's connected to a PIC/PICAXE, the problem is in the PIC/PICAXE. The output of the PIR sensor is just an ordinary digital output and it shouldn't make any difference what it's connected to as long as the output current limit (<20mA) is respected.
I have tested two jumper settings.
I also connected 2N2222 transistor and 1K resistors to the output pin.
2N2222 works fine as the voltage f the base goes higher.
The collector is connected to +4.5VDC (DC battery) with 10K resistor load and measured voltage reading on the load resistor.
Everything works just as I expected except Parallax sensors are very unstable.
As I wrote previously that for an occasion, there is no output voltage when two sensors are completely covered with ceramic cups. So it is definitely the firmware issue in the IC Chip.
Both units give me erroneous voltage reading, even with two sensors are completed covered with ceramic cups.
I just got new one yesterday and this one has the identical problem.
TH
I fixed the jumpy output issue written by Crono1124. In order to have correct response, the power supply must be very stable with no noise.
I tested two sensors and worked correctly.
I had the same problem as Crono1124. I had a dual power DC battery supply to drive several functions such as LED, FAN and other mechanism. Somehow by connecting all of these functions with multiple power supplies did cause to have noise, which affected the sensors. Now I provided a single and independent power source for the sensor only and worked ok. Noise is major killer for these sensors.
I hope this helps.
Best,
TH
I'm glad you got your issue resolved. As a note there is no firmware in these sensors. The entire circuit is like a slowly balancing analog comparator. Slow changes cause the sensor to slowly recalibrate to maintain a kind of equilibrium. However such changes (including noise) will cause the sensor to trigger. And if the trigger happens to activate a fan, relay or some other noise producing device running on the same power supply you can even have a scenario where oscillation will prevent the sensor from ever settling. Often the noise problems can be solved with a couple of capacitors near the sensor across the supply lines.
Parallax Engineering
"The man who smiles when things go wrong has thought of someone to blame it on."
-Lucky[size=-1][/size]
Thanks for any help.
Test your PIR sensor with 4.5 V DC batteries first. This will remove noise and voltage instability issues. The output voltage should be around 3.3 VDC.
You can cover the PIR sensor with a cup to make the output voltage to 0V.
If it works then you have noise or voltage instability or both.
TH
Thanks again for all the feed back. and Patience. :0)
