Four Extra Pins from Sd-Card Slot
I use OLED-96-Prop units for prototyping, as I like the size, little screen, and integrated voltage regulators. One compromise though, is having only four Propeller pins for I/O. This is a report of a "method" for gaining access to 4 additional pins, utilizing the SD-Card slot.
Concept: start with a spare micro-SD card; grind off the surface of this card, such that the card's pads are disconnected from the inner working of the SD-card; carefully solder on four 26-g wires to pads 2,3,5 and 7; gently insert (jam) the modified SD-card into the card slot; test.
I was doubtful that it would fit and even if it did, I was skeptical that it would work. It did require a little extra pressure to get the modified card into the slot, but it did go. To my surprise, the connections between the card and the board are solid: viola--4 more pins!
Attached are three photos illustrating 1) SD card after grinding; 2) after soldering; 3) after insertion into slot, showing path of wires.
Jim
Post Edited (Jamesx) : 2/7/2010 9:31:21 PM GMT
Jim
·http://www.brilldea.com/product_uoledioc.html
Although he doesn't produce them any more, (I guess because 4D doesn't make the OLED-96 anymore), it could be reproduced pretty quickly.
ADDED:
I'm actually working on a project this weekend to drive 16 solenoids from Tim's board for a water feature using the uLED-96-Prop.
Jim
Post Edited (hover1) : 2/7/2010 6:56:58 PM GMT
http://www.sparkfun.com/commerce/product_info.php?products_id=9419
Kal: As for etching a PCB, like the sniffer board, that's a possibility too. Maybe a bit beyond my current capabilities, but something to aim for.
Jim
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
If you wanted to sell extra IC's, that would be great too.
Jim
So - hang in there, I will keep the thread informed on an order and availability.
www.tdswieter.com
