How long can a Programing Cable be?
I wish to make a programing cable to go from my laptop to a project on top of·a light pole.I·will be using
a Propeller Proto Board with the 4 pin header for programing.
Bill S
Bill S
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
Bill S Louisville, KY.
Ben
It uses Cat5 between a pair of modules. Both modules do the necessary signal conditioning and conversion for the long cable. The module at the host end also boosts the +5V USB supply to a higher voltage for transmission. The one at the other end downconverts the supply back to +5V. I've used mine not only for programming, but also to power small remote systems, and it works quite well.
Style and grace : Nil point
I made·a cable 13 feet long with 4 pin headers at each end,·and shielded·wire and it works for my
needs (well it works in my shop) .I'll test it outside when the weather gets a·little warmer.
Bill S Louisville KY
Very fragile, very inelegant but the programme based around 3D noughts and crosses went out.
