Propscope and Labview
Would there be a way I could get the command set needed to control the Propscope? As a student at Univ of New Mexico, I need to do a project in Labview and thought this would be a fun challenge.
David Steidley
David Steidley
PropScope can export data in various formats (txt, csv, matlab, png) to various destinations (filesystem, ftp, and to other applications via scripts). You can also use DDE to interface with it, as well as using the ViewPort Development kit to create plugins for it. Please tell me more about what you intend to do? What data do you want, at what rate? What do you want to control?
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
·Are you talking about Propscope or Viewport having a DDE interface.
Viewport does as you have documented this but I do not remember you
mentioning it in regards to Propscope.
Tom
The project is about Labview. By writing a driver for Propscope, it makes it easier to prove that this isn't just some exercise in sticking together some "off the shelf" parts and ... viola. By doing this, it will be easy to show that I was the one that did it from the ground up. And, to top it all off, I would be doing it for a really cool piece of hardware.
Any help is greatly appreciated.
David
A labview driver for the PropScope would be cool. I think the DDE client/server interface is your best bet-it's so easy! Here, try this:
Start up PropScope
Start Microsoft Excel
Connect ch1 to a known voltage- for example, a battery
Type "=vp|get!ch1" into cell "A1". This starts a DDE dynamic link. The value of cell A1 (usable in formulas or even graphs) will be the voltage measured by ch1.
Type "=vp|get!list" into a cell to get the list of variables you can view.
Download the ViewPort client kit to learn how to use DDE to connect to ViewPort- the same applies to PropScope. It contains samples in Delphi, VB, C#, python, Excel, and even Matlab. It's here: hannoware.com/viewport/clients.php
Tom, yes, PropScope contains a DDE client/server- see above...
Hanno
·I was able to get Delphi 2007 win32 components to connect to
the DDE server in PropScope as shown in attached pdf file.
Just a quick test app. I was not able to reconnect a second time
after clicking on Close Link Button. I Do not know if that issue is
Me,You, or Delphi Ha.
I will have to experiment some more with the DDE interface.
Tom
Looks good!
I don't know why you couldn't reconnect- have you tried the samples in the kit? They do let you reconnect...
Hanno
I pasted images of the obj inspector and the main source.
Tom
Sorry for disappearing on ya like that. I will try out the DDE interface and see how it works. Thanks for the info!
