Solar tracker with bs2 & ds1302 & linear actuator
I am trying to construct a solar tracker that will rotate panels based upon time of day. Basically activate in 8 forward steps and retract at midnight. Have edited the demo program by Chris Savage, but it needs some work. I think I am on the right track, but it needs a do loop or two? This is my first attempt in a long time from programming. Like BASIC and FORTRAN in the 1980's Andy
Welcome to the Parallax·Forum
You have a few problem with what you have
When you use the DS1302 Time Chip you·have to· [noparse]/noparse][color=red]WrBurst[/color][color=white]·[/color]or [color=white]·[/color][color=red]RdBurst[/color
with all of the all of the ·registers· [noparse]/noparse][color=red]secs, mins, hrs, date, month, day, year[/color
·SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrBurst]
· SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, mins, hrs,
Or
·SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst]
· SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year]
Set_Time: ' DS1302 Burst Write HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrBurst] SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, mins, hrs, date, month, day, year, 0] LOW CS1302 ' Deselect DS1302 RETURN Get_Time: ' DS1302 Burst Read HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst] SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year] LOW CS1302 ' Deselect DS1302 RETURN·Now if you just want read one or two··registers· then you have to write it this way
·SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrSecs, Wrmins Wrhrs]
·SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs ,mins, hrs]
Or
SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdSecs, Rdmins, Rdhrs]
· SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, min, hrs]
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/7/2010 12:29:10 AM GMT
·Revised somewhat. In your attached file DS1302-Demo.bs2 I show diferrent pin assignments for Data I/O =pin 6 and Clock =pin 7 from what I find on the Maxim pin configuration chart? I am trying to place my subroutines in the order they will be executed. 1)RTC_OUT (initializatino routine) 2)Set_Time (But I think there should be a DEBUG...something here to allow keyboard input?), 3)Get_Time (the first thing executed in the DO loop), then the comparators to time to If..THEN operate my solenoid).
Andy
Can you post some pic's and a schematic of your project when you get a chance ?
Rob7
Start: DO ' DEBUG Menu DEBUG CLS ' Clear The DEBUG Screen DEBUG CRSRXY, 0, 0, "Press 1 to Set Date/Time.", CR DEBUG CRSRXY, 6, 1, "2 to Display Date/Time.", CR DEBUG CRSRXY, 6, 3, "RESET Stamp to return to menu.", CR DEBUGIN DEC1 work ' Get 1 Number IF work = 1 THEN GOSUB Set_Mode GOSUB Set_Time ELSEIF work = 2 THEN DEBUG CLS ' Clear The DEBUG Screen DO GOSUB Get_Time ' Get The Current Date/Time GOSUB Show_Time ' Display It LOOP ENDIF LOOPSet_Mode: DEBUG CLS ' Clear The DEBUG Screen DEBUG CRSRXY, 0, 0, "Enter 2 digit year, i.e. 05 = 2005:", CR DEBUGIN HEX2 year ' Set Year DEBUG CRSRXY, 0, 1, "Enter 2 digit month, i.e. 03 = March:", CR DEBUGIN HEX2 month ' Set Month DEBUG CRSRXY, 0, 2, "Enter 2 digit date, i.e. 02 = 2nd:", CR DEBUGIN HEX2 date ' Set Date DEBUG CRSRXY, 0, 3, "Enter day of the week as a number 1-7", CR DEBUG CRSRXY, 0, 4, "1=SUN, 2=MON, 3=TUE, 4=WED, 5=THU, 6=FRI, 7=SAT", CR DEBUGIN HEX1 day ' Set Day DEBUG CRSRXY, 0, 5, "Enter 1 for 12 Hour Mode or 0 for 24 Hour Mode:", CR DEBUGIN HEX1 modeFlag IF modeFlag = 0 THEN DEBUG CRSRXY, 0, 6, "Enter 2 digit hour, 00-23:", CR DEBUGIN HEX2 hrs ' Set Hours (24 Hour Mode) ELSE DEBUG CRSRXY, 0, 6, "Enter 2 digit hour, 01-12:", CR DEBUGIN HEX2 hrs ' Set Hours (12 Hour Mode) DEBUG CRSRXY, 0, 7, "Enter 0 for AM, 1 for PM:", CR DEBUGIN HEX1 ampmFlag ' Set AM/PM Flag ENDIF DEBUG CRSRXY, 0, 8, "Enter 2 digit minutes, 00-59:", CR DEBUGIN HEX2 mins ' Set MinutesSet_Time: ' DS1302 Burst Write HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrBurst] SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, mins, hrs, date, month, day, year, 0] LOW CS1302 ' Deselect DS1302 RETURNI hope this helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/13/2010 4:18:37 PM GMT
Okay I modified my code, but when I try to run this the very first I/O line is highlighted and I get " Expected ':' or end-of-line." So, from my manual, it mentions colons are placed after labels. I know this is probably a very simple error, and I feel my intelligence is pretty narrow. The logic I can understand in programming; the syntax is killing me. Anyway, attached is a photo of what I am trying to accomplish. Anyone familiar with tracking solar (PV) will appreciate the advantages, particularly in a windy are, like Wyoming.
Any input appreciated.
Andy
However, If you have clouds, you will have falth signals.
Best to rotate by calculating sun location (for this is quite complex math involved and programming must be at high level of knowledge)
I like "adobejoe" idea. And I came to this idea also, and reviewing it as I am building mechanics for my Solar Tracker.
