Multiple PING)) Code Logic Suggestions
Bill Chennault
All--
I would like to upgrade my robot with multiple pings. It is my thought that if I had 8 PING)) units, I could easily cover the machine's entire "sight distance" out as far as necessary (36" is fine.) However, I can't get a handle on the logic to implement the code which will let me determine the sensor reporting the most distance ("most distance"·would be·a clear path: there are combinations of clear paths, ie; left-front, right-front, etc., but that makes it worse).
Other than a bunch of IF/THEN statements, how would you do it? Maybe it is simple and I am not seeing the forest through the trees.
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
If you want to change the search order, you could just rearrange the PING))) connections so they're scanned in the order you want.
If you have 8 PING)))s, that would take about 160ms to make a pass through all of them.
PingsPins PIN 0 ' as an implied array, using pins 0-7 maxDist VAR Word minDist VAR Word pingDist VAR Word(8) maxPing VAR Nib ' saved idx of ping minPing VAR Nib i VAR Nib LoopMe: maxDist = $0000 minDist = $FFFF FOR i = 0 TO 7 PULSOUT PingsPins(i), 2 PULSIN PingsPins(i), pingDist(i) IF pingDist(i) < minDist THEN minDist = pingDist(i) minPing = i ENDIF IF pingDist(i) > maxDist THEN maxDist = pingDist(i) maxPing = i ENDIF NEXT DEBUG "max dist is Ping #", DEC1 maxPing,": ", DEC5 maxPing, CR, DEBUG "min dist is Ping #", DEC1 minPing,": ", DEC5 minPing, CR PAUSE 2000 GOTO LoopMe▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Mike, thanks for the logic. I am glad I quit thinking about it. I am going to attempt to poll the PING))s in a timed interrupt (SX/B) and return their distances to the main routine.
Zoot! Ha! Thanks for the code!
--Bill
Post Edited (Bill Chennault) : 2/5/2010 8:48:04 PM GMT
