24 Volt to 5 Volt converters
Does anyone know of a 24 (or 12) volt dc to 5 volt dc converter.
Kind of like a reverse ULN2803 chip.
I use an opto isolator on each input but the parts count gets high when you have 32-48 inputs.
I have searched Maxim, AD, Microchip, and Phillips to no avail.
Thanks in advance if such a beastie exists,
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
Plasma Technologies
Canaan NH 03741
I do not need opto isolated inputs, and I have used transistors but that is still 3 components.
A nice IC chip to plop into the Pc board would make life Oh So Grand.
Plasma Technologies
Canaan NH 03741
Maybe some other 5v regulators can take in 24v?
Check out the Propeller Wiki·and contribute if you can.
If you might have spikes or significant noise, I'd use the optoisolators.
Post Edited (Mike Green) : 2/5/2010 3:08:51 AM GMT
Thanks for the ideas.
What I was actually looking for was if anyone makes an IC chip like the 2803 but works backwards.
I currently use an optoisolator (4 per pkg) and it takes 2 resistors per Opto.
Some of my Plasma Machines have 30-40 plus 24 VDC inputs and that equals 90 to 120 parts to insert and solder.
A nice IC chip with 8 or more (I can hope) would make life simpler.
Maybe a 3082NLU would shift 24 Volt signals to 5 volts to feed my Stamp Inputs!!!
Thanks Guys,
Plasma Technologies
Canaan NH 03741
In some old PLC designs I have done I have had a 20-pin socket for the 2803 so that you can reverse the chip to make it an input buffer instead.
*Peter*
