Sparkfun RGB backpack
Greetings,
I'd like to attempt to control an array of these little backpacks from Sparkfun with the propeller. I've read the sticky about interfacing the 3.3v propeller with 5v devices and still had a few questions. With the attached diagram as a reference using the SPI objects, do I need 10k resisters between the Propeller and the SCK pin, and between the Propeller and the CS pin since the backpack unit is 5v based? From my understanding, The 3.3v from the Propeller to MOSI pin should be fine as it is since it's above the logic level.
Thanks in advance and kind regards to all.
Fred
Why be one if you can't act like one? Knoxville, TN
Fred
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Best Regards,
Fred
