How to step down 250V to 96V and dissipate 7.5 kW
Hi-
I know this isn't at all related to Parallax but there is so much knowledge around here I figured someone might be able to help us. We want to do bench testing of the motor for our solar car. It's an NGM SCM-150 pancake motor, runs at 96V and has a peak power output of 7.5 kW.
First question is...we have a 250V industrial outlet in our workshop, I don't remember off the top of my head what it's rated. Last time I checked though it was enough to power our motor at full load if we wanted to. But, how do we convert that to 96V and be able to draw 80A from it? Power supplies that do this exist, but cost at least $10,000.
Second question...we can also power our motor from lead acids we have. Granted, they won't last long at full load, but the question remains, how do we dissipate this much power?
Rafael
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
Rafael
KJ6AWU
Lots of water and some cheap immersion heaters or kettle elements.
Life may be "too short", but it's the longest thing we ever do.
7,5000watts @ 96volts is 75 Amps, so thats a lot of BIG capacitors !!
you probably dont need to regulate it since its for a motor
And I'm not sure how clean the motor controller wants the input voltage to be...
Rafael
KJ6AWU
what does "peak" power mean. i guess startup requirement.
if it is, then maybe you could have an 100Amp transformer/rectifier/capacitor for the average power, and use the batteries for peak delivery.
A normal car battery of 20AH, will give the required 100amps or more when starting a car engine, so 8 car batteries in series.
better put some good protection like fuses/circuit breakers in there though.
hope i have helped
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0504224
its 1KW, so may work, only costs $150
I would try to find a higher output though, probably 2 KW.
I guess you could use 3 1KW ones, and have 3 sets of Xformers/rectifiers/capacitors.
and just wire the outputs in parallel.
since you would have 3 circuits, thats each diode bridge rated at say 20-30Amps continuous.
I would put an ammeter in series with each output to monitor the load sharing
sounds OK to me at a cursory glance
Anyway, where would we get diodes that big?
Rafael
KJ6AWU
One of many suppliers for large capacity diodes...
(data sheet)·· http://www.vishay.com/docs/93521/70hfr.pdf
(price)·· http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=70HFR20-ND
Good success!
DJ
WARNING: You'd be dealing with non-isolated mains voltage on the caps and in the motors, so take appropriate precautions!!! The switching and timing circuitry, however, can (and should be) optically isolated from the mains supply.
KJ6AWU
this is my last reply to this thread.
we are here to give you help and advice, not to do the job for you.
you dont seeem to be able to google "50A bridge rectifer" on your own
I would suggest that you dont have the skills to design this.
a suitable bridge rectifier is 50A continuous, costs $12
http://uk.farnell.com/multicomp/cm5002/bridge-rectifier-50a-200v/dp/9380868
However, to me the question remains: If we use an alternator and resistive heating elements, how to we control how much heat is dissipated at a given time? We can't exactly adjust the resistance of the elements as far as I'm aware of. A teammate suggested a variac with a heating element on the secondary, would this work? As you say, people are happy to furnish others with advice. I am seeking such, not instructions on how to build this test bench. If you feel like I'm asking obvious questions, by all means tell me so and don't do my work for me.
Rafael
KJ6AWU
One thought I had was to use a dynamotor approach, and then I thought what would one look like as far as physical size that could keep up with 7.5 kW?
Then I thought a gas powered generator... the motor/generator is AC but usually that is a matter of wiring.. the size for the amount of power would be about the same. It's not a dynamotor in the conventional sense, the 'primary' is a gas engine as opposed to an electric motor and you wouldn't be able to use the 250 Volts you currently have at your disposal, but by varying the speed on the gas motor (I figure at least a 15HP gas motor) you could dial-in your 96 Volts (I presume you wanted DC) on the 'secondary' ... just to compare prices, a gas generator of that size (7.5 kW) could be had for about $1000
Beau Schwabe
IC Layout Engineer
KJ6AWU
Also, if your going to consider using Bat. in series ... I would recommend using relays to stack the bat's, provided your controller does the stacking (when no current is flowing) Also, make sure the relays are large enough to handle the current, even with the precaution just mentioned, you can weld the contacts together with the kinds of currents·available from a lead-acid bat·... Using relays is a little expensive, but when the circuit is off, no dangerous voltages are present.·· AKA, when the hood is up.
When our company needed to test our UPS batteries, our tech guy rented a load bank and hooked it up to the batteries.
The load bank cooling fans sounded like a jet engine was running in our building, but it did the job.
