Robot Arm
Hi
I am student and i am trying to write program for my project.
The biggest problem is if i move the shoulder u can say up and then i try to move other servo u can say move the elbow·my robot falls. Meaning it fall like i have to also give a command to shoulder to stay there at that angle always but i also wants to give comands to other servo how i can do that.
And also can some one please tell me that how to increase and decrease the speed of servo bcoz i need smooth movements.
one more question like how to move it clock wise or anti clock wise if i am at approximately at 90 degrees you can say at 550
here is what i am doing
' {$STAMP BS2}
' {$PBASIC 2.5}
ccw VAR Byte
cw VAR Byte
iter VAR Byte
main:
FOR cw = 1 TO 35
PULSOUT 15, 110
PAUSE 20
NEXT
FOR cw = 1 TO 35
PULSOUT 15, 800
PAUSE 20
NEXT
FOR cw = 1 TO 35
PULSOUT 13, 110
PAUSE 20
NEXT
PAUSE 1000
FOR ccw = 1 TO 35
PULSOUT 13, 765
PAUSE 20
NEXT
PAUSE 1000
GOTO main
' {$STAMP BS2}
' {$PBASIC 2.5}
ccw VAR Byte
cw VAR Byte
iter VAR Byte
main:
FOR cw = 1 TO 35
PULSOUT 15, 110
PAUSE 20
NEXT
FOR cw = 1 TO 35
PULSOUT 15, 800
PAUSE 20
NEXT
FOR cw = 1 TO 35
PULSOUT 13, 110
PAUSE 20
NEXT
PAUSE 1000
FOR ccw = 1 TO 35
PULSOUT 13, 765
PAUSE 20
NEXT
PAUSE 1000
GOTO main
PULSOUT 15, 110
may be your problem depending on your servo. most can only go down to 200. try changing this to...
PULSOUT 15, 200
and see if this helps. the servos i tried seemed to not have a problem with these values, they came to a stop without jerking, but most will move to the farthest position limit and sit there and jerk, (i have some of those too) trying to move past the internal mechanical limit. usually a pulsout of 250 to 750 will give you roughly a 90 degrees of travel.
as far as holding the servo positions while the bs2 is processing other tasks, you can use the servopal that parallax sells...
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servopal/List/0/SortField/4/ProductID/481/Default.aspx
this nifty lil unit will hold the position pulses sent to it till a new position pulse is sent to it, effectively holding the servo in its position till you send it a different position.
Post Edited (kf4ixm) : 2/4/2010 5:08:09 PM GMT
But i kind of get the (expletive)ion for keeping the arm at the same position because i have to keep giving the arm same comand. By putting same comand again and again when i give other pulsout like pulsout 1,500 and when u again give other comand like pulsout 1,500 pulsout 2,200. This way arm will stay at the same position where it suppose to be and i can give other comands to.
Pulsout 13, 700
pulsout 15, 650
pause 18 (since you used up part of the 20ms)
goto main.
- Stephen
for i = 1 to 25
pulseout 15, previousvalue + i
next i
- Stephen
