Cheap relay-coil/CCFL switching board for Propeller! Switch up to 18V with 3V!
Would anyone out there be interested in a small, cheap board that can switch a relay coil using a propeller. It is a simple transistor switch that is cheap yet effective. I am getting some boards made (through Gadget Gangster) that will fit the Propeller Platform. I have also designed a not-as-cheap Mega board that will drive 16 I/O lines. Both devices can switch up to 20V DC (low amps) or 120VAC 30A if used with a relay. This would be perfect for cheap high voltage control without any complex circuitry. This would also work to switch a CCFL inverter's power source. What are your thoughts on this?
Micro
P.S. Voltage is not switched, it is supplied from the Propeller Platform to avoid need for an outside voltage source.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
Post Edited (microcontrolled) : 2/3/2010 11:39:00 PM GMT
Micro
Hello..... Anyone out there?.......
Jim
