uln2803
Let's Go!
what is the minimum voltage required to operate the uln 2803?·for testing purposes, can one put +v directly from the battery to the input pin to get an output, or does it have to be ttl or cmos input?
thanks
The smarter I get, the more I understand I don't know!
thanks
http://www.sparkfun.com/datasheets/IC/uln2803a.pdf
is that the way it works, mostly?
A relay needs this, because a magnetic field is generated when you turn it on. The collapsing of this magnetic field when you turn it off generates a·current, which needs some place to go. Connecting pin 10 to the +V gives this current some place to go. Otherwise, it will burn out the ULN2803's output transistor.
