bs2 shot? (solved)
bs2-man
i had my bs2 pluged into a 6v 300 ma psp. and i noticed that the power light was off, so i unplugged it plugged it back in and the light lit for like a second and turned off. whats wrong? plz help me!
Post Edited (bs2-man) : 2/3/2010 10:38:13 PM GMT
First disconnect anything plugged into the bs2 except for the power supply. If you have a short (by connecting Vdd with Vss) the light can go out and the board look dead.
From your very brief description that might cure your problem. If not get a meter and check the voltage regulator. Pin closest to the board should be input voltage, middle pin is the ground and the pin closest to the center of the board is regulated 5 volts.
If still having problem, add some more information. Are you on battery, what type battery, what is voltage to Vin plug on regulator? ETC...
Chuck
