USB Oscilloscope 10x probe
I am using the scope (and my digital voltmeter) to explore a vacume flourecent display circuit.
The power supply to the VFD drive circuit is 47V so I need an external probe to view the high voltage pulses from the VFD driver to avoid damaging the scope.
Most conventional scopes that I am familiar with have a 1 megohm input impedance so a 9 megohm resistor in series with the input will do the job.
Can anyone tell me what the input impedance is·for the USB oscilloscope?
Dave
Dave Andreae
Parallax Tech Support·
Using rudimentary methods I·had calculated the input R at 1.3 megohm and the input C at 130 pF.
I expected a margin of error of +/- 50%.
Do you consider my idea of putting a 9 meg ohm resistor in series a safe way (for the scope) to measure higher voltages?
I expect 47 Volts but·I want to have a good margin for error.
Dave
Dave Andreae
I'm building it today
Tom
