NEW: Battery Pack for Propeller Platform
Just put it up a few minutes ago. I'm making a time lapse video to show how long the Propeller last (to convert the non-believers), but I think all the folks on the Propeller Forums already know the Prop is a power miser. Here's a photo:
More Info on the Project Page
Specs:
Battery: 4x AAA - nimh recommended, provides 4.8v to V50, 3.3v to V33
Battery Life:
In stack with a ProtoPlus - full size
Gratuitous module shot - Prop on bottom, then battery, then ProtoPlus, then OctoDriver - full size
The design is available under the MIT license - I'll add the Diptrace file in just a bit.
btw, if you're keeping track, there are now 9 Propeller Platform Modules
DMX IO,
LCD UI,
Prototyper,
ProtoPlus,
OctoDriver,
Propeller Platform,
Tester,
Battery,
uSD,
With more coming soon!
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Specs:
Battery Life:
- 40 Hours 3 cogs running @ 20MHz
- 17 Hours 3 cogs running @ 80MHz
- 8 Hours 8 cogs running @ 80MHz
DMX IO,
LCD UI,
Prototyper,
ProtoPlus,
OctoDriver,
Propeller Platform,
Tester,
Battery,
uSD,
Nice work on the photos and the design. I am eager to hear how the actual tests perform.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
What mAH rating are the Fry's batteries. The solar garden Led lights typically have 900mAH batteries, but I have 2500mAH batteries I use in devices on my boat. I even use them in a modified garden light including a brighter led on my boat. The solar panel does not keep up, but I recharge externally about every 3-4 weeks.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
1986 Chevy EL Camino·· No prop yet
1984 Suzukie GS1100GK No prop yet
The graphics demo with 3 cogs (I took out the mouse object) ran from 1am this morning until 6pm - 17 hours. Not too shabby!
Keystone electronics Part Number "92" (yes that's the complete part number)
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=92K-ND
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
