2 amp DPDT relay - 2A * 2 or 1A * 2
W9GFO
I am using this DPDT relay rated at two amps. Does that mean that each pole is 2 amps (4 amps if paralleled), or is it 1 amp per pole? It doesn't make it clear in the datasheet.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Rich H
Can you link to the data sheet ?
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Here it is again: http://panasonic-denko.co.jp/ac/e_download/control/relay/signal/catalog/mech_eng_tx.pdf
Rich H
Yup just from looking to the sheet its per contact..
Rating
Standard contact: 2 A 30 V DC, AgPd contact: 1 A 30 V DC (resistive load) <<<<<<<<<<<<<<<<< 2A
Max. switching power Standard contact: 60 W (DC), AgPd contact: 30 W (DC) (resistive load)
Max. switching voltage 220V DC
Max. switching current Standard contact: 2 A, AgPd contact: 1 A < this is weird but I assume its because the silver one can't handle as much as plain contacts.
Min. switching capacity (Reference value)*1 10µA 10mV DC
Peter KG6LSE
LOL
Be careful about what you switch. Inductive loads even if they are within the V-A range can arc and weld the contacts shut easily.
There is not much seperation in the PC mount relays.
Be careful of the 30 V Dc rating fr the same reason.
Good Luck
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
