ask for help
stevenyuen
since my school ask me to build a robot which can use the robot to detect a ball and then pick up·the ball( which may have three different calour( red , blue and green) and then sort the···ball.........so i would like to use ping sensor to detect for the distance ball and then go to along with the ball.......can anyone help me to solve this problem...i dont know how to program and use the ping ........can anyone help me................!!!
··········································steven
www.parallax.com/tabid/440/Default.aspx
www.parallax.com/tabid/535/Default.aspx
www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/Level/a/ProductID/92/Default.aspx?SortField=ProductName%2cProductName
Look at the CMUcam which can locate colored balls and control a servo to track the ball
www.parallax.com/StoreSearchResults/tabid/768/txtSearch/cmucam/List/0/SortField/4/ProductID/29/Default.aspx
1) What are you using to track the ball?
2) How big is the ball?
3) What material is the ball made from?
4) How fast can the ball move?
The PING))) has a maximum range of 3 meters, but that doesn't mean it can detect a small object at that range. It doesn't mean it can detect a large object at that range if the object is rounded and made of a material that poorly reflects sound waves at frequencies around 40KHz.
2.) about 5cm in diameter
3.) plastic
4.) the ball dont need to move.....it is at some fixed position inside a square which is 1.5m X1.5m
PG
