Defective or Working BASIC Stamp
I was using the Board of Education, (So I don't know if this is the right place to post) and used the following code to see how it got input:s
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
DEBUG CRSRXY, 0, 3,
BIN1 IN6, BIN1 IN5, BIN1 IN7, BIN1 IN4
PAUSE 100
LOOP
(Just something I got from the BOE-Bot Book)
I had nothing plugged in, and sometimes it gave 1101, others it gave 1111 another 0000, but nothing plugged in. When I removed it from the wooden table, (It had rubber legs so it didn't even contact the table) The voltage input data changed. Is this defective or normal?
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
DEBUG CRSRXY, 0, 3,
PAUSE 100
LOOP
This is why people use 10K ohm pull-up, (or pull-down) resistors to give a definite 'default' value on input pins, even when the driver is disconnected. I say "driver", because USUALLY when you're reading an input pin, you expect it to be 'driven' by some driver output somewhere -- otherwise you wouldn't be reading it.
